Help needed
Help needed
camshaft solenoid is the a diy to replace?
code p00021 car runs fine idles fine.
Cleared the code and it has not returned.
Bank 1 was replaced
Is code p0018 bank 1
and p0021 bank 2
thanks.
Oh the car just had a engine out service plugs pinned hoses
water pump clutch slave and accumulator and shark werks elbows.
Would this cause that code in any way.
Bank 1 was replaced
and p0021 bank 2
thanks.
yeah, replacing the cam solenoid is a doable DIY. Many times, however, this is related to spun camshafts. It may be that the techs forgot to reconnect the solenoid plugs.
I'd poke around in there to make sure everything is plugged in and then pursue cam solenoid.
