Help with center lock wheel tools required.
Rocky Mountain High
I never considered the torque multiplier, but it looks interesting. I bought a centering tool from a RL member named SmokinGTS. It's made of delrin, and it's much less expensive than the 3R Racing version. I'm not familiar with the BMF torque wrench.
Centerlocks definitely add a "PITA" factor to wheel changes, but I think it's worth it for the look.
Rocky Mountain High
i use what's recommended by Porsche literature. It's not that bad. 450 lbs. I have also read that just the torque wrench alone has tolerances. That is why that also gets computed. I don't use a multiplier. I have one.
Also, torque wrench error is usually expressed as a percent, so yes, putting it through a torque multiplier and torquing to ~400 ft/lbs will increase the absolute error, but it should not increase the percentage error...
Not trying to be argumentative, just accurate. I believe the Porsche factory motorsports centerlock tool, 00072194500, is a torque multiplier rather than just a BMF torque wrench, so to imply that Porsche doesn't recommend the use of a torque multiplier is inaccurate.
