BBi Autosport White Porsche 997.2 GT3 RS Track Car Build
Basic Sponsor
Hello everyone! Thank you for chiming in! Sorry for not being able to update this build thread as we are swamped at the shop and producing content takes a lot of time.
We don't know who sells at the cheapest price but we offer the part. Yes, we offer an intake manifold kit complete with gaskets that bolt onto non 4.0 models
- Jerry@BBiAutosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Its not just a bolt right up. To be able to bolt it up, you also need the lower manifolds as well since those are different sized on the non 4.0 motors.
Basic Sponsor
For the brake system, we will upgrading to the Brembo 2-Piece discs, pads, and fluid.
Brake Upgrades
Front
Rear
Front Brembo Type V (endurance face type) Brembo Discs
Rear Brembo Type III (aggressive face type) Brembo Discs
BENEFITS OF BREMBO 2-PIECE DISC UPGRADES:
OEM INTEGRATION: Brembo 2-piece disc upgrades are designed to work seamlessly with the OE calipers and systems (manufactured by Brembo for Porsche). This guarantees the utmost in safety and seamless fitment.
LIGHTWEIGHT: Disc assemblies include an outer iron disc with aluminum bell/hat and provide decreased corner weights to improve vehicle dynamics including handling, acceleration, and braking.
HIGH THERMAL CAPACITY: Greatly improved thermal capacity and heat management over OE discs and other aftermarket discs in the market. This also improves braking performance and allows for greater longevity of the components.
FRICTION MATERIALS: Everything we learn by supporting top professional racing teams throughout the world goes into selecting the best brake pad options for all levels of street, track and racing use.
911 GT3 Front “High Thermal” disc specifications:
911 GT3 Rear “High Thermal” disc specifications:
Brake discs are one of the major brake tuning options which a professional race team has at their disposal at any typical race weekend. There are many subtle changes that can be made to a brake disc casting or configuration which can drastically influence braking characteristics
Type V (Endurance face type): motorsport developed face type with marginally less initial response compared to the type III face type. The Brembo Racing type V face type was also designed to have lower pad and disc wear for certain long distance endurance races (mostly 10, 12 and 24 hour races).
Benefit: braking modulation and control similar to Type III, while offering lower overall pad and disc wear on the track.
Drawback: While the most well balanced of all Brembo face types, Type V discs generally do not have as high of an initial response compared to the Type III.
Type III (aggressive face type): motorsport developed face type with an emphasis on high initial response while maintaining a smooth pedal release.
Benefit: highest overall braking confidence, control, and allows driver to spend less time on the brake pedal. When chasing the fastest lap time, less time on the brake pedal typically leads to a quicker lap time.
Drawback: Any disc with an aggressive face type like the Type III will have a higher chance to mechanically abrade the pad and disc surface leading to quicker or uneven pad wear. However, this really depends on variables such as car setup or track layout.
[B]Brembo RE10 Endurance Brake Pads/[B]
Features:
Front
Rear
Stainless Steel Brake Hydraulic Lines
Brembo Racing HTC64T High Temperature Brake Fluid
Features:
Brake Upgrades
- Front & Rear Rotor/Pad Upgrade
- Stainless Steel Brake Hydraulic Lines
- Brembo Racing HTC64T High Temperature Brake Fluid
- Brake System Bleed
Front
- Brembo Front 2 pc Type 5 Brake Discs
- Brembo Rear RE10 Endurance Brake Pads
Rear
- Brembo Rear 2 pc Type 3 Brake Discs
- 380 x 34 disc – High Thermal
- Type III or Type V “Endurance” slot type available.
- 17 mm air-gap (narrow air-gap for the brake disc to have extra thermal capacity and durability under higher brake demand conditions)
- 72 vane ventilation
- 23 lbs – disc ring
- 24.5 lbs – complete 2-piece disc assembly
- Compatible with 911 Turbo (991) Models
- 350 x 28 disc – High Thermal
- Type III slot type
- 16 mm air-gap
- 14.5 lbs – disc ring.
- 16 lbs – complete 2-piece disc assembly
- Compatible with 911 GT3 and Turbo (997) Models
- Integrates into factory parking brake
Features:
- Provides excellent level of frictional grip in cold temperatures or warm
- Lower operating temperatures greatly reduce fade that results from brake fluid reaching boiling temperature in the lines
- Backing plate and side edges of brake pad have a corrosion-resistant finish
- Center gap allows for proper heat expansion of brake pads
Built in noise-reducing shims
Front
Rear
Features:
- Brembo HTC 64T can handle high temperatures without loss of pedal feel (independently proven low compressibility).
- Has been specifically formulated to provide the highest performance and consistency under all racing conditions.
- Has an extremely high dry boiling point
- The higher viscosity of this fluid delivers a “stiffer” pedal and provides stable performance under extreme temperatures (critical in professional motorsports)
- Boiling Point Dry: 335 C / 635 F
Basic Sponsor
To improve handling, we installed our complete BBi Street Cup Suspension package along with Tarrett Engineering's Adjustable Sway Bar End Links and Öhlins TTX Coilovers. Our upgraded components provided the additional adjustment ranges to help maintain proper suspension geometry that not be achieved with the factory arms.
Öhlins TTX Coilovers with Tarett Engineering Monoball Shock Tops. They look as great as they perform.
BBi Autosport Porsche 996/997 StreetCup Suspension Package
BBi Street Cup Suspension Features:
BBi Autosport Front & Rear Lower Billet Control Arm Kit
BBi Autosport Front Bump Steer Kit
BBi Autosport Rear Adjustable Toe
BBi Autosport Front & Rear Thrust Arm
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
BBi Autosport Rear Upper Control Arm Kit
Tarrett Front and Rear Adjustable Sway Bar End Links
- Hard tested on the street and track
- Provides additional adjustment range
- Helps maintain proper suspension geometry
- Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
- Eliminates factory rubber bushings for improved suspension feedback
- Direct bolt-On replacement and requires no modification to the vehicle
- Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
- Precision Teflon lined spherical rod ends for smooth operation and long life
- Discrete black anodized finish for increased corrosion resistance
- Made in USA
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup arms
- Allows proper camber adjustment 996 & 997 Models
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
- A must have for all track and race enthusiast
- Each kit includes pair of 2 arms
- Fits both front and rear axles
- Helps eliminate bump steer by maintaining proper front end suspension Geometry
- Utilizes misalignment rod ends of the arm to provide maximum articulation
- Highly recommended for vehicles that have been lowered
- Each kit includes pair of 2 Links
- Provides additional rear toe adjustment
- OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
- Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
- Complete set of 4 (2 front & 2 rear)
- Link the rear wheel carrier to the sub-frame.
- Allow adjustment of track width and kinematic toe.
- Complete set of 4
- Simple bolt in replacement for the factory drop links
- Left & right hand threaded rod ends allow for simple length adjustment to eliminate swaybar preload
- Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends
- Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
- High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
- Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
- Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
