R & P 4,00 993 to 996/7 gt3
Hi,
I'd like to change my oem r&p for r&p cup 4.00. I can buy 4,00 of 993 from my friend. The question is: does it fit to 996/997 gt3? Is it the same gearbox? The parts is bought from fvd.
http://www.fvd.de/de/de/Porsche-0/91...ersetzung.html
thanks for response.
Martin
Martin
Basic Sponsor
I think they are the same fitment. What matters is if the R&P is rifle drilled for forced lubrication. If not then you can not use it. Infact I don't think the non drilled shafts even fit with the tail housing in a 996/7-3 trans
I know the input shafts and such are interchangeable other than the difference with the riffle drilled for lubrication and the differential machining for shaft clearance on pre 97
Basic Sponsor
I think the part number you listed is the 993 NON DRILLED pinion, so I do not think that would actually work in a gt3 as they are all rifle drilled.
950 302 911 24, i believe this is the std one
950 302 911 80 I believe this is the rifle drilled one for GT3's
the #24 will only work in non pressure lubrication trans
the #80 will work in both
thanks a lot.
If someone is interested in buying to 993, let me know.
3,89, yes I agree and plus 6th longer gear from mkII rs 97/92, nr 9973029590, for travelling.
I had 4,0 cup in 6gt3 but for highway it was a little bit annoying. 4000rmp 130-140 km/h. Bigger consumption, and noisy. I didi that time lots of tracks (40k km) than it was ok but this 7 is also for weekend jurney
Basic Sponsor
thanks a lot.
