Key got stuck in the ignition. 997 GT2
My key got stuck in the ignition and turning left or right gives me no response. I CANNOT remove the key from the ignition !
My GT2 battery is empty becuse it is been parked for a while with out driving.
So, what exactly should I do to fix that issue?
Anyone had that issue before?
can you turn it all the way counter-clockwise?
put some energy into the battery and see if it'll release...if it doesn't it may need the replacement switch,,,, ignition switch does weird thing
Don't try to jam it out. The key lock is electronic. The car requires some battery power to release the key. There is a procedure in the manual on how to free the hood and key when the battery is flat.
agree is the battery -- happened to me also
You can give the car enough juice to pop the hood/release the key from ignition by opening the fuse box and there is a terminal you can pull out and attach the positive end of a jumper cable to.
Agent Orange
Look at the manual, it gives you instructions how to pop the hood open so that you can access the battery.
I have this in my car, it is very useful and can jump start a dead battery: https://www.cobra.com/products/porta...mpack-cpp-8000
I'm not sure a trickle charger can recharge a completely dead battery.
You may be on to something... It happened on my turbo too...
when u open hood using power to the fuse- be sure u make a good ground or it won't work- i had to mess around with ground a lot b4 it worked to open hood with totally dead battery-
