BBi Autosport Porsche 997.1 GT3 Project Bull Dog with 285 Wide Front Tires
Basic Sponsor
Attachment 1344394
We would like to take a quick moment present this White Porsche 997.1 GT3 that we just completed this week. Nicknamed "Project Bull Dog" for its stance, we installed our StreetCup Suspension Package and widened the front track of the vehicle with GT3 body parts. The result is an extended track wide enough to accommodate monster 285 size front tires and 325 rear tires that delivers extreme grip and race car like feel on every turn.
Vehicle Specifications
Exterior Body Work
Suspension
Wheel & Tires
Interior & Safety
Exterior Body Work
- Porsche GT3 Cup Flare Package (flares and inner fender liners)
- Porsche GT3 Cup Front Fenders
- Porsche Front Bumper Deflectors
- Radiator Bracket Modification
Suspension
- Ohlins TTX 2-way Suspension System
- Tarrett Rear Monoball Shock Mount
- Tarrett Front & Rear Adjustable Sway Bar End Links
- BBi StreetCup Front & Rear Billet Lower Control Arm Kit
- BBi StreetCup Adjustable Thrust Arms
- BBi StreetCup Adjustable Upper Control Arms
- Competition Corner Balance & Alignment
Wheel & Tires
- Forgeline WHeels GA1R 10x19 and 12x19 Wheels
- Pilot Sport Cup 2 Front Tires 285-30-19 & Rear Tires 325-30-19
Interior & Safety
- FVD White Instrument Cluster
- BBi StreetCup Roll Bar
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
To improve handling, we installed our BBi Street Cup Suspension Package along with other upgrades from our trusted partners such as Ohlins and Tarett Engineering.
Common Features of BBi Street Cup Suspension Components :
- Provides additional adjustment range
- Helps maintain proper suspension geometry
- Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
- Eliminates factory rubber bushings for improved suspension feedback
- Direct bolt-on replacement and requires no modification to the vehicle
- Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
- Precision Teflon lined spherical rod ends for smooth operation and long life
- Discrete black anodized finish for increased corrosion resistance
- Made in USA
BBi Autosport Front & Rear Lower Billet Control Arm Kit
(shown in Black Finish w/ optional camber and litronic shims)
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup armss
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust caster and wheelbase
- A must have for all track and race enthusiast
- Fits both front and rear axles
- Part Number BBILOWRCNTRL9697
BBi Street Cup Front & Rear Adjustable Thrust Arms
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Part Number BBITHRUST9697
BBi Street Cup Rear Adjustable Upper Control Arm Kit
- Link the rear wheel carrier to the sub-frame.
- Allow adjustment of track width and kinematic toe.
- Part Number BBIDOGBONE9697
Front Suspension Installed
Rear Suspension Installed
Basic Sponsor
BBi Autosport StreetCup Roll Bar
Next, we installed our BBi 991 GT3 Street Cup Roll Bar to properly mount harnesses and increase protection. Thr roll bar features a 2 piece design and 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio. With our sensible approach, the 2 piece design allows the bar to be mounted to the front seat belt mounts and to the rear strut towers (stronger mounting points). For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit.
Features
FVD Cluster
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to front seatbelt mounts and rear strut towers
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
- Designed to work with stock or any aftermarket seats on the market
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other optional colors available
- Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3
- Compatible with factory Bose subwoofer
- Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
FVD Cluster
Will let Jerry respond, I've seen them do various flavors of this on quite a few cars. I have a wide track front end but with stock fenders, basically using cup lower control arm parts. Car doesn't push. Turns in so good.
Originally Posted by CosmosMpower
Why don't you run wider, like 275 on a 10". You can fit 245 on a 9" stock.
I run a 9.5 with 265 front tire on my car that has full 997.2 PMNA cup conversion.
If I read the specs correctly (tirerack.com for Michelin Cup 2), a 245/35/19 tire should fit perfect on 8,5", is that correct? Any reason 9" is better than 8,5" for this dimension?
I have 8,5" front rim, and is thinking about going 245 front and not stock 235 next time I get new tires.
