Bore vs Stroke in a GT3 Engine Build
http://www.6speedonline.com/forums/t...-j-maring.html
Former Sponsor
Much of the weight savings is away from the centerline of the crank, further reducing its moment of inertia to make it rev faster. The knife edging and the polishing/coating on the counterweights also helps with windage quite a bit--lets it rev freer and make more power!
Ringing bells
Alex,
This is a good subject matter and close to home as I had one of these engines built a few years ago.
I’m sure it was his hope that if he offered up some basic engineering, it may be of help to those that are unsure.
Thanks to Jamie he brought that paper to every ones attention. I’m sure Jamie’s intention was not to start a “Crank” p’’’ing match of who’s is prettier, but to inform about the paper. The paper is written and based at a level of engineering most should be able to understand.
With all of the failures of Cam bolts and Pulley bolts coming loose on these engines, removing material from the counter weights seems “counter” to what others are doing with their Crankshafts. Jamie's Crankshaft looks to have material added to the Counterweights. I'm sure this is for a reason.
If you wish to offer your Crankshaft as a comparison then how about offering some engineering data and expertise that can be shared. It would be interesting to hear another opinion especially if they are engineering based.
Alex,
It would sure make this passtime more fun if we could share more, but this is often at odds with folks making a living doing this. The intent of posting the article was to share some details on the hows and whys of bore vs stroke, and maybe get a few engine builds...
This is a great read for those interested in understanding bore/stroke advantages for street and track engines...
http://performancedevelopments.com/g...-displacement/
Robocop305 (03-23-2022)
That crank looks like a thing of beauty!
Gotta ask this brain trust a tech question:
When you build your motors, what do you do with the wrist pin: On center / off center and if off center, is is symmetric side to side or not? Stock Porsche is offset asymmetric (meaning same piston, both sides)
Ray
Ray
