997 GT2/GT3 Forum 2005-2012
CPO Work on Oil Leak
Old 05-23-2014, 09:15 AM
aircavscout
aircavscout's Avatar
Default CPO Work on Oil Leak
Need some advice from the experts... AKA.. The folks here.
Car in shop getting work done under CPO. Appears to have a fairly significant oil cooler leak fitting on Top of engine. Thought it was RMS but turns out not to be.
CPO is covering the work. They will be pulling the engine.
Since the engine is out I asked for a price to do the coolant hoses / welded.
Dealer gave me a price north of 3K... That seems high with the engine already out under warranty..
Any solid advice on this one?
Old 05-23-2014, 09:33 AM
rnh204
rnh204's Avatar
In speaking with the shop that welded the coolant lines on my car for the previous owner it was ~$4500.
Old 05-23-2014, 09:42 AM
aircavscout
Ok.. So it sounds like that is in line then...
Old 05-23-2014, 11:24 AM
Spyerx
Spyerx's Avatar
Received 1,728 Likes on 1,057 Posts
Once engine is out the labor to remove, clean, and weld the housing should be less than 10 hours. You may want add a water pump depending on miles (~350). Feels a bit steep to me since the bulk of the labor on these jobs is the remove and replace of the engine. I'd ask if that $3k also includes replacement of a bunch of other rubber hoses while engine is out.
Old 05-23-2014, 12:12 PM
Alan C.
Alan C.'s Avatar
Wow! $3000/$150 per hr. = 20 hr. to remove the parts which are right in front of you after the engine is out. The welder won't spend more than 2 hours with a TIG torch. A friend recently experienced the same problem you described. His was on a 2010 GT3.
Old 05-23-2014, 02:10 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,715 Likes on 1,624 Posts
Sounds like they are charging like it's 2 separate jobs. The cpo will cover the removal of the engine, oil leak fix and the reinstall.
Then Porsche service charges for the removal again, welding and reinstall, without actually removing the engine again.
Old 05-23-2014, 03:27 PM
AEsco48
AEsco48's Avatar
Pin it...
AEsco48
AEsco48's Avatar
I bet the dealer is having to hire some one to come in and do the welding...
Old 05-23-2014, 04:45 PM
aircavscout
Dealer is sending items over to have welded... I called and pushed on the price today and got the story about how in depth the job was and blah, blah, blah... I was figuring around 2K.. I called some local NON PORSCHE dealer type's and they gave me quotes around 2500 starting from scratch..
I guess I will just go ahead and bend over since I want it done. I guess that is the other advantage Porsche has with CPO.. You go in for warranty work and still drop 3K..
At least they didn't balk whatsoever on fixing the oil leak. Read all the horror stories about denied claims.. I have 6 months left on CPO... Only have 9K miles on car..
Old 08-25-2014, 10:32 AM
AEsco48
AEsco48's Avatar
aircavscout, please check your PM
Quick Reply: CPO Work on Oil Leak
