Coolant reservoir location in '07 gt3?
Apologies, but I don't have my owner's manual with me. I was doing a regular visual inspection of the engine bay and noticed the opaque reservoir on the left side low in fluids. Is that the coolant? Also what's the standard coolant brand/type to buy?
yes on the left.
Made by Genuine for Porsche. Its Pink now
some people mix it w/ distilled some dont.
That reservoir holds some decent volume and usually never drops it's level... If it's low, check or get the car checked for coolant leaks to be safe...
yeah - those caps are complete total crap - and i mean crap
similar to the brake fluid caps in the front trunk
everyone should keep a spare of both if headed to the track
but do check for leaks
Look for any white residue around the cap. If the leak is in the plumbing from the radiators (up front) to the engine (in the back), most likely it would be caught by the plastic coverings on the underbody and never make it to the ground.
Fill it up to max while cold and see if you notice further drops. Checkout the cap, and get up in the front end with a flash light and the radiators, and if you're so inclined, pull the underbody panels and check the lines for any of that white residue, check as many of the engine coolant pipes that you can.
These are closed systems and you shouldn't be losing coolant.
Thanks guys. So once I get the coolant, just open cap and poor in until full? No need to flush out or anything else? I googled this and saw some folks mention problems with air in the system.
Air in system generally occurs with a flush...topping off shouldn't create any problems. Read the instructions on the bottle re mix concentration.
