Brake rotor recommendations
I have PFC08's on the way to replace the OEM pads on my 997.1 GT3 (2007), and I want to replace the rotors while I'm at it. The car is mainly street driven although it also does see track duty. Any recommendations for rotors, and where to buy them from? OEM rotors from Suncoast are around $1K front and rear.
From researching the forum, it seems like a lot of guys are running OEM rear rotors and PFC slotted fronts. Where are folks buying the PFC rotors from?
Thanks for any help.
4th Gear
vividracing.com provides the Brembo 2-piece slotted steel rotor replacements and I have found them to last at least 4 times as long as the standard drilled steel rotors on the track.
Eddie correct me if I'm wrong but the advantage to going with PFC over brembo is the PFC disk is thinner and allows to use a thicker, longer lasting pad, right?
I'm almost positive that you cannot fit a 19mm on Brembos, but I could be wrong.
I believe you're right about it. I only had brembos a hand full of times over the past few years.
Basic Sponsor
Drew,
997.1 will not take the PFC slotted rotors unless your car was a original PCCB car converted to
steel. PFC slotted rotors are made to fit PCCB converted to steel cars or all 997.2 cars. PFC slotted rotors are 378MM believe your current rotors are 350MM.
PFC does make 350MM dimpled rotors but they only take 17mm pads because of thickness.
PFC slotted rotors are thinner and this is how they take the thicker pads.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
Drew keep the stock pads for the street...the PFC08 pads squel like crazy and have a real dirty pad dust to them. Also street pads stop better when cold on the street but for a race pad the 08's don't do bad stopping on the street.
I used Pagid Yellow front and black in back and currently have PFC08's all around on the car and they both are loud as heck on the street. For some reason even on the track my pads squeal.
^^^ Yup...PFC08 pads are awesome.
Contact Deputy Dog on this forum. He has the intel on great inexpensive rotors for 997.1 GT3...he's had them all.
