997 GT2/GT3 Forum 2005-2012
Street Tire Pressure
Old 10-31-2012, 12:49 PM
Serge944
Serge944's Avatar
Default Street Tire Pressure
Am I the only one surprised at the low recommeded tire pressures on a 997.2 GT3?
29/31 psi, really?? The 996 GT3 was 32/39. I know the Porsche Turbos are close to 40psi.
I gave Porsche the benefit of the doubt, ran the recommended tire pressures, and got a puncture last night. As far as I know, low tire pressure is the main cause of punctures. Are all of you running the factory spec tire pressure, without issue?
It was a slow audible leak, and the factory tire sealant did not work. Maybe I'm just pissed that I wasted 2.5hrs last night on a flat tire... Serenity now!
Old 10-31-2012, 01:03 PM
ChrisF
ChrisF's Avatar
Sorry about the flat. That sucks.
Yes. I've been running my MPSC's at those pressures with zero issues over 5 sets. I would imagine you could comfortably run them a little higher so long as you bleed off a little pressure if you go for a spirited drive. They seem to like 32f/35r hot.
Old 10-31-2012, 02:24 PM
GT3DE
GT3DE's Avatar
No clue. I take my stock wheels/tires off my cars as soon as I get them.
I usually start cold at 18 rear and 20 front - but that is for R6 Hoosiers. lol
Old 10-31-2012, 02:50 PM
Serge944
Serge944's Avatar
Porsche dealer called, guess I ran over some yellow steel bracket. Probably debris from some of the construction work in the area.
Now the objective will be to take more right hand corners...
Old 10-31-2012, 05:24 PM
911rox
911rox's Avatar
The cups I ran as specified on the tyre placard... For street tyres (ie MPSS), I run them at turbo tyre pressures as per the michelin book, ie 36/40.... Hope this helps
And sorry to hear about your troubles...
Old 11-02-2012, 01:00 AM
10 GT3
10 GT3's Avatar
I doubt the tires pressures had anything to do with getting a puncture. I had a rear tire blow earlier this year, so I too have been through the roadside assistance/flat bed tow. It is just part of owning these cars. For tire pressures on the street, I run 34 psi on all 4 corners. I have a fairly aggressive alignment and this helps a lot with tire wear on the street without being too harsh. BTW, when I had my 996 I never ran the Porsche recommended 36/44 psi on the street. Ride was terrible. I always ran 38-40 out back. Just experiment and figure out what works best for you.
Old 11-02-2012, 02:45 AM
Nick Wong
Nick Wong's Avatar
29psi front/ 33 psi rear, GT2. That's what I run even with the wider front street tires with soft sidewalls. On the track I run Cups at the recommended hot temps as per Michelin guidelines.
Old 11-02-2012, 01:54 PM
Serge944
Serge944's Avatar
Yeah, I've come to grips that the tire pressures probably didn't have anything to do with the incident...it was a piece of steel that cut into the tire.
But, I will have to give a plug to Power Porsche in Newport Beach. My car was towed by Porsche's roadside service, I got a new Michelin PSS installed by around 1pm the next day, and the total came to $432. The tire alone is $420 from Tirerack. I'm extremely impressed with the overall dealership experience.
Old 11-02-2012, 04:09 PM
mikymu
mikymu's Avatar
flash wound. you should be able to drive that thing all the way home on bare rim. it's a GT3 ... it's tough as nail (no pun intented)
Old 11-02-2012, 04:41 PM
ADias
ADias's Avatar
PAG has been steadily reducing cold tire pressure recs. The 991 (light load and <160MPH) is 31/34.
PAG uses now 2 criteria: load and sustained speed.
Quick Reply: Street Tire Pressure
