Direct Injection carbon buildup
My DD is a 2011 Audi S5, lovely car and sounds fabulous with its Stasis exhaust. I have it in at the dealer right now for an oil change with 21,000 kilometers on it (13k miles). I had been noticing lately that it was not starting well when the engine was hot and felt down on power. They now have the intake manifold off and are de-carbonizing the valves and intake manifold.
I found this article on the problem: http://www.autoobserver.com/2011/06/...-adopters.html Interesting it says that Porsche doesn't seem to be having a problem... |
Originally Posted by Leigh2
(Post 9855976)
I found this article on the problem: http://www.autoobserver.com/2011/06/...-adopters.html Interesting it says that Porsche doesn't seem to be having a problem... There is an aftermarket oil catch can you can install to fix it |
Audi is not the only one that suffers from this.
It becomes a maintenance item. Here's how you actually fix it: http://www.motorvac.com/index.cfm?PAGEPATH=&ID=38819 |
Originally Posted by Serge944
(Post 9856250)
(Post 9855976)
The best solution to this issue is the design in the Flat-4 motor used in the budget sports cars, Subaru BRZ, Scion FR-S, and Toyota GT86.
There they use 2 fuel injectors per cylinder. One is inside the combustion chamber (DFI) and one is farther up the intake air tract. The second one acts to wash the intake and valves (like a traditional non-DFI motor). This allows all the benefits of both DFI (fuel economuy, high compression and specific output, HP/Liter) and non-DFI (no carbon build-up). I wish Porsche and others would adopt this technology... |
Common problem w/ the DI Audi motors.
There was a dyno chart around where a guy lost like 35 rwhp over 20K miles due to the carbon build up in his Audi. Other engines don't have the problem and it has to do w/ vapor routing and some other fine details. |
1 Attachment(s)
It can get pretty bad...
(Post 9856991)
that's why my RS4 dint stay long.
BMW also got this issue in addition to other stuff |
Originally Posted by Hoosier_Daddy
(Post 9857136)
Yikes -- I'll say.
explains why 2 year old ttrs are cheap here... |
BMW 335 are like this to. Walnut blasting usually is the best option.
Originally Posted by Veloce Raptor
(Post 9856470)
Drive the Audi harder... :evilgrin: Not too many problems like this that a good old Italian Tune Up can't fix :D
I run Shell fuel and hammer the car hard after it reaches normal operating temps and haven't had another problem in two years. My RS4 has a nice power surge at around 4500 RPM all the way till it shuts off at 8200 RPM like the 4.2 liter DFI V8 motor should. |
(Post 9856470)
Interesting solution to go to 2 injectors... |
Originally Posted by 911S4
(Post 9857742)
Bought my RS4 with 23k miles, dealer took of manifold and manually cleaned valves 3k miles later under warranty due to power loss.
