New shoes on, finally! E88 content
I was contemplating running the wheel with the spacer but decided against it as BBS states, "For use without factory spacer". It looked close and I didn't want to have it rub and have to remove the wheel again as I just wanted the car back on the ground. If someone knows if a +59 is possible without rubbing, then I'll toss them on.
Almost! It needs some suspension love.
[quote=RAudi Driver;9645338]The rear E88 centers are the 288108's. They are a et +64 so I took off the 5m spacer.
I have Volk +65 offset and keep the spacer on with the PSS 305s - so adjusted offset is +60
It will fit
The good thing with that offset is that you can likely fit a 325 tire without the spacer but then a 305 with the spacer.
It will fit
, you guys are causing me more work. Ok, putting the spacers back on after I get back from loaning another member my stock center section.
Wow that is just an absolute perfect setup!!! It really makes the car even more aggressive looking...ever consider also adding an RS wing? droolll
Gold looks great with white black and guards red...well done Audi...those will never go out of style.
