Agreed. VIR and Glen times are remarkably similar.
For years my Glen and VIR times were identical. But as I got faster and faster, the spread became about a second....something about those blue bushes makes me hold a little more in reserve
Originally Posted by TRAKCAR
+1. I only have one dry day at WG with lots of slow traffic but I never broke 2.10.
I'd get there with more time and ignoring blue bushes...
WG felt more difficult to me.
IMO, vision, and where you are looking, is key to making the blue bushes a non-entity at the Glen. A lot of what I coach advanced drivers & racers on there are specific things to look at in key corners that scare folks so they literally do not see blue. The result of this is faster entry speeds, sooner to WOT at exit, slightly more efficient lines, and a MUCH more relaxed demeanor behind the wheel with no Code Brown moments.
Was told by a couple of different pro racers to do that - so you don't have torque in the throttle as you bounce around and upset the car when your foot is bouncing around, especially since don't need much acceleration thru esses.
Great driving. The higher the speed of the turn, the easier it is to get throttle-on oversteer. Also, the higher the gear, the more precisely you can control the throttle, so use taller gears in high speed turns where throttle balance is more important than acceleration.
There are many places on many tracks where being in one higher gear is MUCH faster and MUCH more stable...
