My GT2 build over the last year
Thanks for the info Nick,
I find the most interesting information from the above to be you tender rates - I think that potentially has a lot to do with it - potentially.
I did a lot off work on tender stuff when I was doing my suspension and posted information about it - I'm gong to guess, that given your 60/80 f/r tender rates, that your car at rest likely 'just' fully compresses the tenders.
Is it possible if you could track down more information on these tenders - i.e. the key information is what is the Block Load for each.
For example, Swift Springs has a 60 Tender that has a Block load of 617#s but it is a 72mm free length spring. I'm guessing yours might be very slightly shorter (maybe 60mm) and this would put the block load 'around' 500#s. Given that the sprung front corner weights are just above #500#s, this is likely a key part of the magic of the suspension - effectively you are riding around on the mains - but just - as the suspension enters slight extension the combo tender / main rate comes into play, which in the case of your front (60/120) combo translates to 40nm or 224#s. The rear (80/230) combo translates to a 60nm or 336#s.
I would really appreciate it if you could track down the Block Load for each of the Tenders
Many thanks
Paul
I'll PM you my cell # and email but anyway through Champion I'm easy to reach.
They are also doing the axles on the RS to make sure all's bulletproof with the power.
Stay in touch.
Ranger (Sua Sponte)
(Juan)
Many thanks
Paul
Many thanks
Paul
I've always read your tech posts on springs and spring combinations with great interest. I don't have that data with me, but if you call up RE Suspension and ask for Jason Enders, a very good friend of mine from karting and the "E" in RE, he can probably tell you everything about the springs down to where the steel was mixed... RE Suspension is the biggest Ohlins distributor in North America and the biggest Penske distributor in the world- if they don't have the info you seek, noone does.
Last edited by Nick Wong; 05-22-2012 at 12:05 PM. Reason: Ipad autocorrect speeling
Paul-
I've always read your tech posts on springs and spring combinations with great interest. I don't have that data with me, but if you call up RE Suspension and ask for Jason Enders, a very good friend of mine from karting and the "E" in RE, he can probably tell you everything about the prints down to where the steel was mixed... RE Suspension is the biggest Ohlins distributor in North America and the biggest Penske distributor in the world- if they don't have the info you seek, noone does.
Thanks - I ordered all my Swift stuff through RE Suspension so I actually have an account with them. I will call them in the next week or two and get the data.
Thanks again.
Paul
Nick, sensational build. Can't wait to see it in action next year against the GTRs.
All that I lacking is a co driver. May I suggest our resident self proclaimed everything expert and OLOA critic. Your freind and mine, Rad.
LMFAO
LMFAO
Nick,
I cold called Jason for a chat.
He is going to try and be helpful.
As these kits are small sample kits and can be one off specced by seller, without actual part numbers it is difficult to know exactly.
That said, I was able to see some part numbers by zooming in on a Champion post about this kit and the two main springs (front/rear) had the key part numbers 120 and 230 as you suggested - the part numbers are entirely unreadable, if there at all for the Tenders.
Jason is going to do his best - but if you happen to have a flashlight handy, next time you are around the car can you see if a part number is visible on the tenders.
thanks
paul
thanks
paul
Targa Tim- thanks!
Yorkshireman- do you intend to play at the front or back? It's an honest question... If I were to drive One Lap I could play in the front 20 easily, but to get to the top three my friend takes charge. He's a former Carrera Cup UK, FFSA le Filiere graduate, Seat Cupra Cup, and Palmer Audi competitor, not to mention top ten placings twice (10th in a Seven, 4th in a Supra) in One Lap. It's important that you get along with your codriver- my codriver is my FRIEND first and foremost, and we have a hoot of a time.
Paul- good you got to talk to Jason. Great guy, really knows his stuff concerning shocks and springs. When I get back from halfway around the world I'll take a look at my car to see what the part numbers are on the springs.
[QUOTE=Nick Wong;9551422]Targa Tim- thanks!
GT2 FTW!
Enjoy and be safe.
GT2 FTW!
Enjoy and be safe.
Nick, this is a very impressive build, quite expensive, but worth it in every way.
This car must be running 800Hp or so, 3.8 with new VTG Turbos, and custom tuned for race gas, a monster.
Is this the same car that wanted to challenge my lousy Fiat at Sebring on street tires? I feel honored, I cannot compensate for a 300Hp deficit, no matter how I drive.
Great choice on the suspension package, a friend is running the same kit in his 997.1 GT3, and I would go with the same kit if I were driving a 997.
Are you on the stock PCCB rotors and stock pads?
Check the gearing in the GT2 RS, the 997 GT2 is geared awfully tall.
My favorite GT2, is it true it is for sale?
Nick,
thanks
paul
thanks
paul
The wheel rates in the front and rear axle are significantly different in all the 996/997/986/987, hence the split on spring rates, even more with the 996/997 due to weight distribution.
I ran over 10 different suspensions in my Fiat, in my quest for the package that gave me the best results, including stock suspension (with Titanium springs), Moton MotorSports 3-way, F430 Challenge shocks/springs, for the stock and Moton shocks, I ran a variety of spring rates, ultimately, I have been on the last suspension setup for almost a year as I found the happy place, rear springs are almost 2000#, and my tenders compress fully at rest. Car is soft on the road despite of the stiff springs, shock valving does the trick.
Targa Tim- thanks!
However, OLOA has plenty of categories, and one can run in a category, shoot for 1st place in class, despite of the overall results.
I know how much time I lose to a Pro at certain tracks, as in the past I had the chance to watch them driving customer GT3s when I had my GT3.
I think Top Ten is achievable by the average Joe with a good car, but Top 5 requires monster car and monster driving.
Now, I have to wait for the 2013 OLOA schedule, and develop a plan to take a 1st in some sort of class, like 1st place in the hybrid-SUV new class for 2013.
