997 GT2/GT3 Forum 2005-2012
Angle of Attack Recommendations (997.2 GT3)
Old 04-19-2012, 11:50 AM
Ajjra
Ajjra's Avatar
Default Angle of Attack Recommendations (997.2 GT3)
The angle of attack on my wing is currently -7.5 degrees. I have a 997.2 GT3 and I'm looking for recommendations for Road Course settings. I am not going to change this from track to track, so I'm looking for a setting that is versatile. I primarily drive at Watkins Glen and NJMP.
Thanks for any help.
Old 04-19-2012, 11:53 AM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,412 Likes on 754 Posts
As much wing as possible for those tracks...
Old 04-19-2012, 12:14 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Exactly max wing, add a 2nd Gurney rear and CUP lip in front..
Rake might have something to do with downforce so I maintain factory rake.
Old 04-19-2012, 12:36 PM
Larry Cable
Larry Cable's Avatar
Received 3,433 Likes on 2,244 Posts
where?
p.s
only downside of max wing is rear visibility on the road...
Old 04-19-2012, 01:11 PM
TRAKCAR
TRAKCAR's Avatar
Good point, maybe one of these years orbit will finally make me taller uprights ;-)
Old 04-19-2012, 01:13 PM
NJ-GT
NJ-GT's Avatar
I tested my 996 GT3 with wing at stock position, and wing at 8 degrees at Watkins Glen. I lost 3 mph prior to the bus stop with the max wing, but the car felt planted through T2-T3-T4 and it felt faster around the track.
I would go max wing for Watkins Glen.
NJMP, no idea, haven't been there.
Larry Cable
cant you use the cup uprights with the 3.8 wing??? - I thought those were taller?
Old 04-19-2012, 01:16 PM
Veloce Raptor
Yep, spot on! Most folks ;have the fear that they will lose straightaway speed. And while this may be a factor at Daytona, at most other tracks the 3mph you lost prior to the Bus Stop is an excellent trade-off for picking up 5-10 mph in many of the faster corners. And IMO the same holds on either config of NJMP, which are both much mor etechnical than the Glen.
Old 04-19-2012, 01:17 PM
Larry Cable
I always thought that the 8 setting on the 996 was considered the "wet" position... but I guess with the .2 4.0 they exceeded that ... I used to run full on my 6.1 and while losing some vmax it planted the rear better
Old 04-19-2012, 01:23 PM
911SLOW
Admin
911SLOW's Avatar
Originally Posted by Larry Cable
where?
p.s
Nope. Worst downside is drag.
Old 04-19-2012, 01:26 PM
Larry Cable
good point! - that too!
Old 04-19-2012, 01:28 PM
911SLOW
Admin
911SLOW's Avatar
The holy grail of race car aerodynamics is: increased down force with a low/zero drag penalty.
Old 04-19-2012, 03:01 PM
Yorkshireman
Yorkshireman's Avatar
In the book "speed secrets, professional race driving techniques" it says "it's very rare that taking off wing results in faster lap tomes". I run 10 deg on my 997.2 NB and I can't see a darn thing in the mirror. It feels planted though.
Old 04-19-2012, 04:26 PM
TTurbine
TTurbine's Avatar
997.2 GT3 tested at home track with wing at highest angle vs stock was around 1.5 seconds faster
Old 04-19-2012, 07:42 PM
Larry Cable
NICE!!!
time to step into the garage I think!
I still have a hankering to get someone to design an adapter that would allow the RS CF wing to be mounted on the back of a NB ... I know ... I know ... I should have got an RS
Quick Reply: Angle of Attack Recommendations (997.2 GT3)
