4.1L adventure begins
#31
it will be in same area as cup car engine rebuild or 3.9 sharky work.
imho if you are after such fun it is worth to buy your own lift and do most of work in your own garage. will probably save you $10-$15k this way.
#32
as usual with such projects - if you have to ask - you cannot afford it.
#34
Koro in Germany build 4.6 and 5.0 GT3 engines, very very rare though, only a few in the whole of Europe, never seen one myself.
http://test.koro.de/en/products_streetengines_gt3.html
A thought come to mind, how do they get such larger displscements without having an issue with the oil pump?
Oh btw, thank you 911slow for posting the pics.
Ranger (Sua Sponte)
#35
Admin
I think that Koro is out of business.
BTW their numbers were not conservative. A better word is "realistic".
#37
I would be happy with 400HP at the wheel or 485HP at the crank = +50WHP and 70HP (crank).
#38
Don't the 997 3.6's normally make around 380 to the wheels? They always seem to make more hp than porsche advertises. I would expect much more out of it considering the expense.
#39
The 485 crank hp is a realistic figure that I think you will achieve. But that's not what you should be focusing on. The most pronounced change you'll feel will be in the low end/mid range!
Drivetrain losses are typically <10%, so figure more like 435-440 to the wheels.
#40
Since your tearing your engine apart , why not just do it right with ported heads and cams?
I dont think the head porting or new modified cams will cost you as much as the engine assembley?
#41
All cams have tradeoffs.
#42
Thanks for clarfying i thought they were similar to turbo mezgers
#43
Anyway, my last Dynojet reading was 350WHP so I'll be using that as a reference point. It's useless IMO to compare HP ratings across various dyno's used.
Cheers,
#44
Just spoke to my Japanese engine builder who used to work for TRD Japan. He said the pistons I got from Capricorn are apparently made by Cosworth. He will also make sure they are blueprinted so there are no disparities in weight. :-)
#45
amazing, sound like your on the right track. cant wait to see some pics and hear more. Good luck silverboy - this is going to be off the wall with goodness
