997 GT2/GT3 Forum 2005-2012
Disc & Brake bed-in
Old 02-20-2012, 05:50 AM
BBMGT3
BBMGT3's Avatar
Default Disc & Brake bed-in
My brake pads and discs are about toast.
Am preparing to mount my new Brembo III's as well as a fresh set of PS29 Yellows. Am currently running OEM discs and Pagid Yellows.
The discs have a pretty specific bed in procedure which I intend to follow, as do the pads.
Here's my question. Do I:
1) Mount the new discs, and bed them in using old pads, then mount the new pads, and bed them in on the new discs
2) Mount the new pads, bed them in on the old discs, then mount the new discs and bed them in using the new pads
3) Mount both together
Thanks!
Old 02-20-2012, 09:17 AM
Mvez
Mvez's Avatar
Bed in both the new pads and discs together.
Old 02-20-2012, 09:18 AM
NorthVan
NorthVan's Avatar
I have had to do all three ways at one point or another. I didn't notice a difference in performance or life on any of them.
Old 02-20-2012, 09:31 AM
NVRANUF
NVRANUF's Avatar
+1
Old 02-20-2012, 09:51 AM
TTurbine
TTurbine's Avatar
Same over here , Just that the brakes do not produce noise when bedded in properly
Old 02-20-2012, 09:54 AM
mdrums
mdrums's Avatar
+1...I was told and read to bed in new disc's with old pads. However this was something I looked into during a Sebring 12hr race and a few teams told me and I witness new pads and new disc's going out in practice sesions to be bed in.
Also about the bed in proceedure....I see race teams start out at driving around 5/10ths and pick it up on every lap....brake are then bed in.
I have put new disc's on with new pads...Pagid RS29 Yellows for front and RS14 Blacks for the rear and just drive normally to the track and do a light to medium 20 minute warm up session. I've never had an issue or noticed any difference than new rotors and used pads.
Old 02-20-2012, 12:00 PM
Laertes
Laertes's Avatar
On a sort of related note, if one swaps pads in and out (stock pads for street use, Pagid yellows for track days) do the pads need to be re-bedded as stringently as Pagid recommends each time, or is a more gentle start slow and work your speed up approach sufficient?
Old 02-20-2012, 12:12 PM
Seth Thomas
Seth Thomas's Avatar
Laertes: Work your way up to speed approach is all that is needed. The street pad material that is on the rotor's face needs to be brushed off by the track pad and the track pad material deposited on the rotor before you really start pushing in the brake zones. A lap or two gets the job done. The main reason for bedding pads in the first place is to put the pads through a heat cycle much like you do tires.
Old 02-20-2012, 12:55 PM
Izzone
Izzone's Avatar
Buy pfc
No bed in required
Old 02-20-2012, 01:05 PM
BBMGT3
BBMGT3's Avatar
Why use a street pad? Just use whatever pad you use on and off the track. Unless you are running scary racing brakes that don't do anything when cold...
Old 02-20-2012, 03:16 PM
Laertes
Laertes's Avatar
Because the Pagids squeal like a school bus, and rotor wear even when on the street seems about 5x faster than with stock pads. Since I swap wheels out anyways when headed to the track an extra two minutes per wheel to put in the pads isn't a big deal......
Old 02-20-2012, 03:51 PM
FFaust
FFaust's Avatar
If you are inclined to do a bit of reading. Also the FAQ is pretty good.
http://www.stoptech.com/technical-su...and-procedures
Old 02-20-2012, 05:14 PM
Seth Thomas
Originally Posted by Izzone
Buy pfc
No bed in required
+1000
Best pads on the market that are good all the way to the backing plate!
Old 02-21-2012, 01:15 AM
tcsracing1
tcsracing1's Avatar
tell me about it! the ol' school bus squeal is horrible.
next time around it is PCCB for me.
Old 02-21-2012, 10:40 AM
Nordschleife
Nordschleife's Avatar
and which of their plus points leads you to that conclusion?
R+C
Quick Reply: Disc & Brake bed-in
