997 GT2/GT3 Forum 2005-2012
DIY Coolant Fitting Fix with Motor In the Car
Old 03-13-2016, 01:30 AM
  #121
Ur20v
Ur20v's Avatar
View of the engine lowered in the chassis to gain acess to the water pump and pullies etc...
Old 03-13-2016, 01:32 AM
  #122
Ur20v
Ur20v's Avatar
View from above....
Old 03-13-2016, 01:42 AM
  #123
Ur20v
Ur20v's Avatar
Big thanks to Steve for making this DIY and hopefully with others adding detail and tips we can make this a very painless job!
Old 03-13-2016, 03:01 AM
  #124
Ur20v
Ur20v's Avatar
Note I replaced the fuel filter and coolant tank, pressure cap and level sensor, fresh Prsche coolant and Power steering fluid (Pentosin CH2025) as well as a new belt, idlers and tensioner pullies all OEM ex Pelican Parts (thanks guys)
Old 03-29-2016, 10:14 PM
  #125
Vanos13
Vanos13's Avatar
Thanks to everyone who contributed to this thread. I recently completed this job on a 996 GT3. A few comments that might help other 996 owners.
The 6 fittings shared with the 997 are very doable with the engine in the car using the procedure in this thread.
Accessing the two fitting unique to the 996 on the oil cooler casting requires removing the left and right coolant flanges on the heads as well as the AC/alternator bracket. Even with those items removed it's very very tight. The left side is doable if you use a shorter than average tap but I wouldn't recommend going through the effort of removing the additional pieces to access only one side. I didn't find the right side accessible with the engine in the car.
Hope this helps.
Old 03-30-2016, 02:22 PM
  #126
JarmoL
JarmoL's Avatar
Hope this helps.
Good info, thanks!
Old 03-30-2016, 04:50 PM
  #127
Turboslut
Turboslut's Avatar
Which Loctite product are people using?
Old 03-30-2016, 09:10 PM
  #128
Perimeter
Perimeter's Avatar
Default HOW MANY FLUSHES, ANYTHING FOREIGN OBJECTS SIGHTED?
Fantastic thread - Thank you
It probably goes without saying that a coolant flush or two (or three) is done afterwards for good measure. Has anyone looked and found any of the feared drill tailings?
Originally Posted by limitedslip
What a thread! My only question is why isn't it stickied?! If it wasn't for the recent bump I would've missed it!
Thanks Steve W and contributors. I'll be sure to tackle this when I have some free time and report back.
Originally Posted by Greg Lab
Wow, impressive work, undaunted...
Old 04-01-2016, 12:15 AM
  #129
FFaust
FFaust's Avatar
This is what I used
Old 04-01-2016, 01:16 AM
  #130
Turboslut
Turboslut's Avatar
Good choice....If I am reading this correctly, it actually gets stronger with exposure to coolant.
https://tds.us.henkel.com/NA/UT/HNAUTTDS.nsf/web/64A7D871A6324F6285257473004A0B3D/$File/2620-EN.pdf
Originally Posted by FFaust
This is what I used
Old 04-01-2016, 10:22 AM
  #131
tgil
tgil's Avatar
Please contact me if there is any GT3 owner n the greater Philly area that has the skills and desire to do the pinning. I'll pay for any tools and parts needed. Willing to negotiate compensation for your time. I would love to have a GT3 owner do the fix if possible.
Old 04-01-2016, 11:15 AM
  #132
CosmosMpower
CosmosMpower's Avatar
Find a good race shop that does a lot of fabrication and they can knock it out. I had my neighbor who owns a track prep/race/fab shop do mine and he's never worked on a GT3 before, wasn't a problem.
Old 04-01-2016, 11:46 AM
  #133
Turboslut
Turboslut's Avatar
Not sure if you guys ever saw my post in the turbo section...
https://rennlist.com/forums/997-turb...explained.html
Old 04-06-2016, 10:44 AM
  #134
tgil
tgil's Avatar
Cosmos, thanks for advice - I have nothing against Indy shop doing work as I paid up for expensive IMS, clutch, RMS fixes on C4S. Was thinking for GT3 coolent pinning I would prefer a GT3 owner with the skills if possible.
Old 04-06-2016, 11:26 AM
  #135
CosmosMpower
I don't think there are specific skills, it's drilling and tapping in tight spaces. More of a need for specific tools to do the job correctly.
Quick Reply: DIY Coolant Fitting Fix with Motor In the Car
