997 GT2/GT3 Forum 2005-2012
DIY Coolant Fitting Fix with Motor In the Car
Old 01-06-2015, 09:33 AM
  #91
CosmosMpower
CosmosMpower's Avatar
Originally Posted by Steve W
After you're done pinning, before restarting the motor, you can open the two coolant drain plugs on the bottom and all the coolant in the engine along with any debris will flush down and out. Drain it into a big clean 5 gallon bucket and after you can pour the coolant through a coffee filter into another bucket. If you pin it right and according to the directions I gave you, you should find none to almost negligible debris in the filter, but any, the above method will give you peace of mind. To do a full system drain/flush follow the directions below by disconnecting the hoses at the coolers.
About 2-3 gallons will remain in the system (heater system and such).
After that I prefer to refill with fresh Porsche coolant keeping the coolant to water ratio at 20% as per the GT3 Cup specifications below. Since the initial fill has formed the protective anti corrosion coating within all the internal walls of the cooling system components, the subsequent refill of a 20% concentration is all that is needed to maintain the corrosion protection. The mix of 80% distilled water also makes for a cooler running car as water absorbs and dissipates heat much more efficiently than coolant, anywhere from 10-20 degrees cooler over a 50/50 mix. I also add about 4 teaspoons of Jet Dry to the coolant to improve the surfactant properties of the mixture, which decreases water tension and improves wetting of the internal surfaces, just as Water Wetter claims. I am not a fan of Redline Water Wetter because I don't think it has the same anti-corrosion protection additives at the Porsche coolant, seems to have no lubrication for the water pump, and I've seen where it causes strange fallout of chemicals in the cooling systems.
Thanks great write up, will be doing this on my GT3 soon.
Old 01-06-2015, 09:41 AM
  #92
flyingpenguin
flyingpenguin's Avatar
I am really happy with the knurling / JB welding so far. Time will tell but from an engineering perspective it makes a lot of sense:
https://rennlist.com/forums/997-gt2-...l#post11825638
Old 01-06-2015, 04:31 PM
  #93
CosmosMpower
Originally Posted by The Beanster
Sharkwerks has a three piece kit to replace the plastic fittings with aluminum.
Are these pieces you can get to with engine in the car or have to R&R the motor to replace these elbows?
I got the fittings pinned, thanks to the OP for the great write up.
Old 01-22-2015, 06:22 PM
  #94
rensprt
rensprt's Avatar
Stupid question, but can you not wire the hose clamp to the motor to prevent the pipe from coming out. It will need to be repaired but could stop fluid from dumping on rear tires.
Old 01-23-2015, 03:16 PM
  #95
AEsco48
AEsco48's Avatar
There is maybe 1 fitting you could loop safety wire around the clamp and then around another component, the rest would need a PITA... and that's based on pictures of the engine out of the car.... In car would be another story...
When mine failed it was a catastrophic coolant dump and when I looking in the engine bay with a flashlight the fitting had not completely popped out of the hole, just backed out a bit and unseated. At 15PSI even just a slight gap allows quite a bit of fluid out rather quickly...
Old 01-25-2015, 03:32 PM
  #96
rensprt
rensprt's Avatar
Too bad. I figured it would not work but good to rule it out.
Old 02-03-2015, 12:31 AM
  #97
lmnsblu355
lmnsblu355's Avatar
Is anyone concerned re: galvanic corrosion between the aluminum housing and stainless bolt in the presence of coolant?
Has anyone used aluminum socket head screws rather than stainless? Shear strength should still be more than adequate, no?
Old 02-03-2015, 02:01 AM
  #98
997s07
997s07's Avatar
Galvanic corrosion won't happen since the there won't be "electron transfer" from the metals. There's no potential. But, there could be other issues.
Old 10-24-2015, 10:34 AM
  #99
Rick GT3
Rick GT3's Avatar
yesterday finished pining ( 6 )the left side of the engine, alternator also installed back. now this week will do the right side. also did clean engine bay.
who ever wants to do this task, do it slowly, make sure you feel comfortable working on engines.
BIG THANKS to Steve W for posting this DIY.
Old 10-24-2015, 10:35 AM
  #100
Rick GT3
Rick GT3's Avatar
btw Steve W if you come to PR I will invite you for a cool Medalla...
Old 10-24-2015, 01:48 PM
  #101
robbieracer
robbieracer's Avatar
Nice, I plan on doing this soon.
Old 10-24-2015, 03:36 PM
  #102
Steve W
Steve W's Avatar
Glad it was of help! Cheers!
Old 10-25-2015, 08:55 AM
  #103
Greg Lab
Greg Lab's Avatar
Wow, impressive work, undaunted...
Old 11-05-2015, 07:45 PM
  #104
Rick GT3
Rick GT3's Avatar
finally GT3 engine pinning is done, last Monday did the right side of the engine and assemble everything back the same night. Did start the car 24 hrs later and no leaks.
Steve W, thanks again.
Old 11-05-2015, 10:20 PM
  #105
997s07
997s07's Avatar
Wow. Great job. How long did the actual labor take?
Quick Reply: DIY Coolant Fitting Fix with Motor In the Car
