997 GT2/GT3 Forum 2005-2012
Centerlocks - I'm out! ....Hello 5-lug conversion!
Old 08-20-2011, 02:31 AM
masmole
masmole's Avatar
Awesome Doug! Way to be the pioneer in all this. The parts price list is actually less than I expected. I look forward to how it all turns out for you, which I trust will include a nice write-up with photos, not that I have any interest in doing the same or anything
Is this conversion going to end up on your next European Car mag feature?
Old 08-20-2011, 02:34 AM
Larry Cable
Larry Cable's Avatar
Received 3,630 Likes on 2,357 Posts
doug has done all the r&d on this ... and a vendor gets to profit!
Old 08-20-2011, 09:04 AM
997gt3north
997gt3north's Avatar
If you factor in dealer labor rates, could it be cheaper to order more parts to avoid the labor? Have you calculated this alternative cost and could you post this information
Old 08-20-2011, 10:45 AM
DJN
DJN's Avatar
I haven't decided where it will go yet, but I felt that this was extremely important for our Rennlist group to know about this ASAP.....so enjoy the fruits of my labor!
Again, I had lots of help, but certainly led the "investigation".....Yes, sure the vendors and Porsche (AG and dealers) will "cash in" some, your thanks and encouragement is more than enough for me......ok, I'll accept beer or single malt!
Great question! Yes, I have done a few senarios, but one can't get around the HUGE cost of new wheel carriers......for example the front wheel carrier for 2010/11 is part number 997-341-157-93 and one of them goes for $1462......enough said, .......the labor cost will be much cheaper.
Cheers!
Doug N
83benz (09-06-2021)
Old 08-20-2011, 11:21 AM
trophy
trophy's Avatar
Well Doug the cat is out of the bag
Looks like we have some work to do.....
Old 08-20-2011, 02:57 PM
ChrisF
ChrisF's Avatar
Received 1,026 Likes on 380 Posts
Love the ingenuity of this board. Looking forward to the full write up. Best of luck!
Old 08-20-2011, 03:29 PM
911SLOW
Admin
911SLOW's Avatar
A drawing to see the parts mentioned:
wheel hub
angular contact bearing
BTW I noticed that the tension bolt in the front has a different part # between the '08 and '10 cars.
996 341 131 04 vs 997 341 131 00.
Probably not an issue.
Old 08-20-2011, 04:01 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,665 Likes on 773 Posts
Let me know how your studs hold up
Old 08-20-2011, 06:58 PM
deputydog95
deputydog95's Avatar
Stud Hater I would switch to studs myself if I could find a set that fit properly. Either they are too short or way too long. Can't win.
Kudos on the conversion. I myself, am waiting for the 991 GT3 to come out before I make the switch. I'm hoping 5 lug will be an option, but it looks like even if its not there will be a work around. Good to know. I have become very attached to my cordless impact wrench and the ease of lugs.
Old 08-20-2011, 09:14 PM
rlips
rlips's Avatar
Do you have to address rotors as well?
Old 08-20-2011, 09:47 PM
1198r
1198r's Avatar
I have a "special" Talisker single malt you can share with me! Or as porsche would put it - Talisker 1957 LE!
Old 08-20-2011, 10:18 PM
mdrums
mdrums's Avatar
Call John at BGB Motorsports in Daytona...they do studs on all the Grand Am Porsches and know how to do the job...while you're there get a proper string alignment.
Old 08-21-2011, 10:27 PM
DJN
DJN's Avatar
Yes, we do Steven.....this should be a fun one, during and after.!
Note to Rennlisters: Steven gets free rain of my 60+ Single Malt Scotch bar for helping with this one!!! He's a great "Bloke"!
Yes, John indeed you are correct, thanks for pointing out. However the nut is the same part number (so the threads are the same) and the length of the hub barrels going through the bearing are also the same. Also, I believe the new carrier requires this new "tension bolt (stub axle, likely a new inside end design)", so everything should be fine.
See the link for race studs in my original post, these ones come in 3 different sizes.......I picked the smallest and have already checked them for length. Perfecto!
No, not on car with standard brakes......sorry not sure on ceramics (different wheel carriers), but I don't it being a problem.
Ah.......now here is a gentleman! Thank you, I'd be happy too!!! Also, let me know if you will be in Calgary, and I will pleased to share any of my "LE's" and other favorites with you.
Cheers to all!
Doug N.
Old 08-21-2011, 11:31 PM
savyboy
savyboy's Avatar
And I can vouch for Doug being a mighty fine person to hang out with and talk "gasoline" A real gentleman.
Old 08-21-2011, 11:36 PM
9972RS
9972RS's Avatar
so which 5-lug wheels have the correct offsets?
Quick Reply: Centerlocks - I'm out! ....Hello 5-lug conversion!
