clear bra cleaning tips??
Here's the product you're looking for:
http://www.premiermobilegroup.com/pf1_products.shtml
Known as PF1-TTR.
Deanski
Known as PF1-TTR.
Deanski
plexus does n't work on clear bra if you track the car hard. if you can wipe off rubber markes with plexus, trust me you didn't bumper draft close enough.
TTR from premier is the ****. i have never seen anything like that. so i presume its toxic, so make sure u re wax the bra. after TTR i use premiers cleaner then follow with crystalline. it's better than any wax, wax tends to turn clr bra yellow. i have white car, i see it clearly how it changes color if you waxed it too much.
yes, as AV430 said, you can buff wax polish film, but dont use too much pressure, it will be damaged.
For those interested in seeing how well the product works (with photos):
http://www.6speedonline.com/forums/g...ar+bra+cleaner
http://www.6speedonline.com/forums/d...ar+bra+cleaner
PREMIER PROTECTIVE FILMS
ClearGuard PPF Specialists, Spectra PhotoSync IRD & CeraLuxe IRD, Authorized Modesta and Nanolex Dealer
www.facebook.com/premierprotectivefilms
B: 510-623-1308
sales@premiermobilegroup.com
See Our Projects! http://www.facebook.com/premierprotectivefilms
CLEAR BRA CLEANER -TRACK MARKS ON CLEAR BRA - PF1 TTR!
B: 510-623-1308
I bought a load of plexus when I got my car fully wrapped, useless, not recommended at all.
Tried different stuffs (mothers pro-line cleaner, waxes, polishing, etc), useless.
Then ordered a load of Premier Film Cleanse, Crystalline and TTR. Pretty happy with this. After a wash, I use TTR to remove tire and rubber marks, use light pressure, no orbital buffing or porter cable, it will scratch the film (I did that already). Then Film Cleanse, and then Crsytalline. Amazing Products.
TTR will not remove cone marks from autocrossing, of hitting apexes on track days. The only product that successfully removed my cone marks was Acetone, but it ruins the film. Paint or Lacquer thinner doesn't work to remove the cone marks either, unless you buff strongly and that scratches the film as well.
Sometimes I wish I had the car wrapped with 3M. I had my 996 GT3 with 3M (whatever generation was new back in 2004), and I was able to remove cone marks with just 3M Imperial Hand Glaze (doesn't work on my Venture Shield either).
Thanks Mooty and landjet!!! Yes, our TTR (not updated to our website) has been released for close to a year now. Prior to that, our R&D team spent over 100 hours in finding a way to clean track rubber. The most common complaint was that track rubber is not coming off the film, but can be removed off the paint just fine. Our PF1 TTR was successfully designed so that it can remove harsh transfer marks without damaging the film.
Will TTR take out some ugly yellow bug stains and is it okay on a 3M bra? Also, anytjing for some minor swirling?
Thanks.
I have the 3M film and use TTR. It removed a stain that other products wouldn't. Premier told me to be sure to use a detailer after TTR because it needs to be neutralized.
Received 1,722 Likes
Unfortunately, we are currently not running any promotions. As for ordering our TTR or any other PF1 products designed specifically for your paint protection film, please contact us at 510-623-1308. Thank you!!!
