Exhaust sound control at your finger tip
#31
Had the remote switch installed at TC two weeks ago along with all my track prep stuff. Fantastic mod for sure and after doing the LS date in June will also install the bypass. Glorious so far!
#32
I added the Carnewal remote today - great addition, very easy install - took less than 15 minutes all done.
My system is EVOMS headers, OEM Side Mufflers and Sharkwerks Rear Bypass.
No drone, and it can pass noise tested track limits - or not!
#33
Seems like we have the exact same setup. I also run the carnewal switch with EvoMs/ sharkwerks headers, oem sides, sharkwerks bypass and their custom tune for it all, and have been very happy with it. The way the carnewal switch works is it allows you to open or close the valves independently of the sport button. It will no longer open up at 4k anymore. It's either closed all the time or open all the time. Pressing the sport button no longer affects the valves.
#34
EVOMS should just offer this as an option within their DME flash product -- just reprogram the valve to either be full open or closed based on the stock Sport button. Hardware from China always breaks and I will just lose that remote dongle after time.
#35
That's a great idea, hopefully the EVOMS guys take your input onboard
Perhaps Sharky could lend his support for the idea as well
