GT3 and GT3 RS ride height
There's a lot of variation of opinion on car setup for track and street.
Castor, camber, toe-in etc... GT3 vs GT2 rear sway... etc
Question, in addition to all the other variables....do most folks retain the stock ride height, or have many lowered their car, and if so by how much? Keeping in mind street driving is still a mandatory activity!
The car drives really nice with a 15mm lowering from the factory height. Please note that some cars come higher than stock; the allowable variance is +5mm/-0mm; mine was about 5mm higher up front than the factory setting. There are pics in the archives somewhere of what the car looks like at 20mm and 15mm of lowering from the factory baseline.
Platinum Dealership
mine was lowered at various heights between 7mm and 10 mm lower than the factory setting, can't remember exactly what I set it at but probably -10 in front and -9 in back
i raised my RS as high as i could adjust the bilstein damptronic coils.
i did it for ground clearance for tarmac rallying. It is actually practical for DD, however can anybody tell me the negitive effects of this? how much worse should the car handle on the track? will it make it stiffer?
i ask cause i never drove my car in stock trim or in lowered track trim.
The suspension geometry built in to these cars benefits from a fairly low ride height, although you do need the proper shocks to work at that height as well. Basically, the stock PASM shocks, or even the Bilstein Damptronics don't have the proper droop limit, and won't handle a really low ride height. If you want to take advantage of the geometry benefits from being lower for track use, you have to run shocks accordingly (Moton, JRZ, etc.) that have static height levels at the lowered ride height, and have travel to work at the lowered ride height.
Basically, if you don't intend on upgrading your shock / spring package, you have to run close to factory euro height for everything to work ok. If you are open to 'upgrading' shocks, you have more options with regards to ride height and the related 'benefits' that can be had for track set-up and lowered ride height.
Camber settings are a function of ride height, tire choice and driver ability / preference. Toe settings are equally critical, and your car should be fitted with cup-type rear toe links if you intend on lowering the car much and tracking it.
If you are intending on street driving primarily, with the occasional track foray, you should stick close to factory ride height, consider putting in some toe links, and engine mounts at the most, and get someone who knows these cars really well to set up / spec your alignment. These cars were aligned very poorly out the factory doors, and benefit substantially from alignment improvements (done correctly, of course). The spec should be based upon your tire choice and the other factors presented prior.
This is a pretty loaded question that you ask...as you can probably tell.
It's also predicated upon your intended use of the car. Hope that points you in the right direction, not intended to confuse anyone ...
Have some suspension bits and pieces on order (Thanks Alex and Dan... Sharkwerks!!), will sift through the search data to see which direction I'll aim towards...
Thanks for the input guys!! .... experience always trumps opinion!
My car used to be at Euro ride height, but after having the dealer reset the alignment to my specs, they put at NA height. It was noticeable different, both in terms of feel and in certain approach ramps.
Took me a while to realize they changed the height, but it definitely felt a bit less stuck to the road at the NA height. When I have a chance, I will get it back to Euro height.
