Dynamic Engine Mts...retrofit = not
if they can go on a 07 turbo i'll install them too. I switched to the stiffer ones a while back and I could tell exactly the difference in ride quality on bumps etc when i switched..
Please let us know if they can also be fitted in earlier cars like mine as well. I would be interested even if they only get activated with the Sport button.. (no automatic switching back and forth).
To be honest I think that would be good enough... It may be possible to get a signal from the PSAM but likely too much of an experiment.. So on/off will be just fine.
I will explore this..
I have them but haven't driven one without so hard to say definitively. I'm definitely not opposed to them. I'm also not going to concoct some story about how wonderful they are and I can tell exactly when they adjust. The car is great on the roads, and very crisp on the track but you would have to compare '10 GT3 with and without to get a good feel since the suspension is so different from the MKI or anything else.
I haven't but I rarely drive without sport mode on. I'm currently on vacation but heading back tomorrow so I can give it a try when I'm back.
The problem is we dont know what kind of signal they require to get activated.. Does anyone have this information by any chance as i cannot find it? I am willing to be the first to try to do this if i get this info..
I want to try to have it work with the PASM sport button
There should be a retrofit, but it may also require an ECU updgrade and wiring harnesses. With auto dimming mirrors and rain sensor, for example, you can retrofit. You have to wire in new wiring harnesses. The harnesses for PDEM should be available through parts. The active part of them means they have to act of a computer based on sensor inputs. The question is, how are they controlled? As the Dynamic Engine Mounts are part of the PSM/PASM programming I would expect any retrofit to include at least an ECU flash.
...of course you could also just find a car that already has them.
My experience so far is I don't notice any noise or vibration. In sport mode, the car picks up immediately and feels like it has a lightweight flywheel. Ride is dead soft in non-sport mode, much softer than a 991.1 GT3 or even a Panamera. Part of this may also be due to the PDEM.
I want to see the concensus as to how much of a difference it makes. And i am talking real difference, not "between your 2 ears" difference.
the 997.2 gt3 is more comfortable on the street than the .1, mainly due to the revised suspension, even without dynamic engine mounts.
Best I can do is to say that my .2 with PDEM turns in much better than my .1 (even with the GT2 rear swaybar) ... is this because of PDEM or not? I cant say.
For what it's worth, my '11 GT3 optioned with DEM has a lot of NVH at around 3k rpm cruising on the highway in non-sport mode as well as sport mode. Vibration, rattling and buzzing sounds from the door panels, etc, which I just assumed to be normal being that this current GT3 has even less sound insulation from the factory than the previous generation.
