Mobonic's new suspension build
Thanks, sorry to be a pain. I'm dialing mine in too and just trying to gather as much info as possible. Can you tell me how many total clicks the JRZ's have from full soft to full hard? Trying to extrapolate that info over to my Motons, although that may not be comparable.
see my attached setup sheet for the JRZ race shocks on the 07GT3RS, as well as corner bal. & allignment spec.
last sheet of attachement
car is unreal
car is unreal
RWK thanks..
so your shocks settings were:
Compression ---------- Rebound
Front 4 4
Rear 4 6
Were these on JRZ's or Motons?
I have been using a lot more rebound and compression like:
Front 6 9
Rear 7 10
Front 4 4
Rear 4 6
Front 6 9
Rear 7 10
too much rebound damping will slow the wheels return to the pavement, after compression. Sometimes I like more rebound on braking in choppy stutter bumps, but...
Too much compression damping will upset the chassis as it will not allow the shock to compress fast enough to absorb the bump.
seems your initial settings are pretty far out on the scale
hope this helps
hope this helps
