18' wheels and set up for track use
GT3 player par excellence
Originally Posted by GT3 Nut
Toyo RA1 245/40-18 front and 305/35-18 rear
or was it NT-01?
My advice is to contact a proven setup shop in your area. Experimenting with wheel/rubber combinations has been done several times over. The change from 19's to 18's involves more than brake clearence.
Here's some info on rolling diameter:
Stock
235/35-19 25.5"...............................305/30-19 26.3"
RA1
245/40-18 25.6"...............................305/35-18 26.3
275/35-18 25.5"................................335/30-18 25.9
PSC
265/35-18" 25.2"...........................345/35-18 26.2
235/40-18" 25.4"...........................295/35-18 25.2"
....................................................315/35-18" 25.5"
Hooters
P245/35-18 24.7"...........................315/30-18 25.6"
Stock
RA1
PSC
Hooters
Originally Posted by mooty
i thought RA1 had 315 that will fit GT3?
or was it NT-01?
or was it NT-01?
Forgot to add, my refernce is to the 996GT3.
The RA1 has the same rolling diameter as stock (997GT3).
LVDell, as for the 996, I think multiple people have been successful with the 18" RA1s. Check out posts from NJ-GT and Seth Thomas.
My choice was to use stock 997 18" carrera III's (new factory take-off from eBay $1200). Weights and observations posted here.
https://rennlist.com/forums/997-turbo-forum/311291-stock-wheels-tires-weighed.html
Just FYI, the 997GT3 rear wheels are even another 2 pounds heavier per corner than the 997TT wheels.
Thanks Jeff, I have actually talked to others who tried them and found rubbing at serious compresion. The RD is larger than the 30 series enough to cause problems under heavy load/compression in the rear. There are a couple of 'listers that used them and verified this.
Originally Posted by AgingRacefully
Important-- if you are going to get the most out of the GT-3, get a good race shop to put an agressive allignment on it. You won't believe the improvement over the stock settings (again, a compromise by the factory to make the car more street friendly)
Have fun, Rick
