Will people be ECU flashing 997GT3's..
Basic Sponsor
Yes, I'm doing my RS, and a couple friends are doing their GT3s. Premier Sports Car Service already has it ready to go...they're going to be doing my car up.
What HP/Torque increase are they quoting for the 997 GT3 and have you seen any dyno results? Personally I wouldn't flash the ECU without first seeing dyno curves. A modest power increase isn't worth blowing the warranty.
you know a lot of very talented engineers have worked out the optimum mapping for the car and implemented it in the car as delivered.
On a standard car with a normally aspirated engine, what benefits are you going to get? Just how many horsepower do you thing the engineers at Weissach left on the workshop floor? What sort of knowledge do you imagine the 'chip engineer' has that the engineers who developed the car at Porsche don't have?
Be very aware that it is possible to record 'better' dyno figures by means other than increasing horsepower.
If somebody does a proper re-engineering job and actually changes such items as cam shaft timing, or the air box for example, then the reprogramming of the ecu will allow the maximum benefit from the modifications to be realised. Without physical changes to the engine's set up, the benefits of reprogramming may be purely illusory.
R+C
R+C
R+C
R+C
I'm with R+C. "Chipping" an FI car is a whole different ballgame than a n/a car, much less one making astonishing hp/L numbers.
Aftermarket turners will certainly advertise incredible gains and take your money, but there just won't be much left on the table with these motors. The new 3.6L is a balanced, blueprinted and lightened version of the old motor already. . . what else do you want?
R+C
R+C
