I do wonder whether 996 vs 997 made a difference in this comparison.
Also, what I don't get is how the Numeric added to the notchiness, as I don't recall the shifter had anything special other than changing the materials to metal-only. Other than the re-centering spring pulling the shifter ever so slightly back to the middle, the shifter does not have any resistance when I was playing around with it before the install. Is it because of the plastic factory cradle that helped to provide a tiny bit of flex to help? Or did the very small change in throw length (at the longest throw setting) have such a big impact? This is more of a question in itself that I never really looked into or figured out.
This shifter thing is like the exhaust situation. So many combinations !
Well the 996 throw is definitely longer than the 997, so maybe that's what I'm feeling? My 7.2 GT3 was notchier and took more effort than the 996. That's not a critique, because I just think in general the 996/997 gearbox doesn't shift all that great compared to other cars. This is why we are all splitting hairs over these shifter mods. Other platforms don't have these type of debates over and over from what I've seen. But I completely understand - when you have a shifting experience that you like, the driving experience changes a lot.
Numeric is short even at the longest setting.
The 996 without any mods was really flappy and soft and had way too much play like an old pickup truck or something. The 996 with the FF mods has a long throw but quite smooth. My own personal preference is for a longer throw. The condition of your clutch itself also has a role in how smooth or how much effort you need to come out of gear.
Ya ... I don't think other platforms are discussing to death on shift cables and shifters. I guess for some they also don't have companies that make such an elaborate setup (outside of CAE). Plus maybe they have other issues to deal with ...
But ya. Shifting is such an integral part of the driving experience. My guess is the Numeric at longest setup still shortened the throw by some 15% on a 997 GT3 shifter (I didn't measure this). I do feel it might help a little if the longest throw can be half a notch longer. Though that might make the shifter sit a bit too high ...
I thought I remember someone re drilling their Numeric to increase the throw length closer to stock. Might be worth searching around the forum some.
I am also still curious to see if others have tried the FF green cables.
This is my sentiment as well. I think I have to give some leniency to a cable shift car, but in comparison to some gold standard shifters (5, even 6speed NA/NB Miata, S2000 (bit redundant as it's the same 6spd Aisin as the 6spd NBs), etc), it's a bit lacking. I love the car but the inputs are a bit heavy and slow to my taste.
My car has cup car cables, I'll definitely look into the FF greens when these wear out.
20227039[/url]]I thought I remember someone re drilling their Numeric to increase the throw length closer to stock. Might be worth searching around the forum some.
I’ve had the same thought about the Numeric being a throw length issue on these platforms and it’s the only thing that makes sense to me about why everyone loves Numeric on every other platform but the reviews are so mixed on the 996/997 GT cars.
I'll also echo what Chris Cervelli told me about improving shifter feel/effort on these boxes. He said it's really a function of of the clutch/flywheel inertia more than anything else. I think making the throws longer slows the whole shift down some to help. He mentioned his favorite option is the 996 cup or 996 shifter with the FF bearing kit.
I run the FF cable ends and the FF shifter kit (I chose the middle throw of the 3 options, supposed to be longer than the Porsche or Numeric short shift kits).
I also have the FF trans insert (orange, medium) which made a significant difference in vehicle feel and shifting.
This is on a 2008 C4, stock flywheel and clutch.
Feels good to me and no increased NVH other than a little bit of "tightening up"" from the trans insert. Shifter is precise and direct, but not too "short" and not to "rifle bolt-ey", but much more precise than stock.
Yeah for sure engine/trans mounts in tip top condition helps a lot. I also use the FF trans mount inserts. I also use the 964 RS engine mounts.
FF green cable install pics if anyone is interested. The cables are very well insulated on the outside so that they don't rattle. That's probably why I didn't notice any added NVH.
Here's a quick video I recorded just now to see if you guys can get a sense of the shifting. This is at idle with the clutch in. When driving it's the same as this as long as you aren't shifting at 2500rpm or something stupid like that.
996 shifter, FF bearings only without the FF shifter, FF green cables, FF trans insert, 964 RS engine mount, 4.0RS clutch/SMFW. It's smooth, fast, and effortless.
Wow, I have 997 porsche original SSK+FF besrings + ff ends+ ff insert + 964rs mounts. Only difference is ssk and cables. Second gear I have not really like you, so probably will do the cables.
I got a chance to test drive a friend's 992.1 GT3 Touring today and wanted to make the same video as above. To my surprise, the shift is also long but it's just the stick itself doesn't stick out as tall. You can tell from the video comparing with my 996 video that when it engages the next gear it doesn't have a "clicking into place" type of sound. It's a soft and smooth engagement, whereas my 996 (with all the mods) would be like a smooth with a bit of a better "clicking into place" engagement feel.
Thanks for the detailed photos and videos. I think one of the contributing factors for these Function First cables not transmitting additional NVH is the Delrin cable ends. Numeric cables also appear to be much stiffer than Function First's. It's almost impossible to keep the Numeric cables bent without using force, while the FF cables can lay down curled up it seems.
My Numeric cables were well insulated with all the necessary grommets and insulators. The problem with Numeric cables is it's transmitting the noise rather than producing the noise itself.
Anyway. I guess when I could spare the cash and time to do the parts + install, this is worth a shot ...
