997 GT2/GT3 Forum 2005-2012
Elliot's 7.2GT3RS Journal
Old 12-31-2022, 02:24 PM
  #181
Bxstr
Bxstr's Avatar
Received 3,211 Likes on 2,194 Posts
Originally Posted by vma1788
Nice list for 2023. Is that cupholder the entire unit or just the covers? My car is cupholder delete but i think i can spare the weight addition for the convenience.
Super bummer about the thickness of the seat cushions. I was actually considering seeing if i could find someone to make mine much thinner opposed to installing lowering seat brackets. When i track my car I run an alcantara Sparco cushion and the increased headroom is perfect. Would like a more permanent solution.
The DB Cupholder trim is the trim only. Not the cupholder.
When I inquired with Kim at P1Designs about thinner foam, she mentioned she could make the foam 3/4" thinner than stock. I believe stock P1 foam is 2" thick. She told me this would cost $50 additional. This was in 2020, not sure what has changed since then.
Elliotw44 (12-31-2022)
Old 12-31-2022, 02:50 PM
  #182
Elliotw44
Elliotw44's Avatar
Received 1,040 Likes on 426 Posts
I've been enjoying the additional conform and easier exiting the seat for street usage. For track days I play on taking my OEM set with me and swapping. The only permanent solution I know for lowering the 997 buckets is available from Cantrell. They have an adjustable seat bracket which goes lower then stock. Lowest setting is 1.25 inch drop. Product here: https://cantrellmotorsport.com/produ...side-mounts-2/
For the 997.2 RS cupholders weren't standard but a no cost option. So both our cars don't have the option. I am just wanting to install the cup holder mechanism back since I would enjoy being able to have drinks when driving.
Originally Posted by The Mick
Seats look fantastic! Did you supply the fabric?
Talk with Kim from P1Designs they have a ton of fabrics and I'm sure you'll find something to match your desired colorway.
Old 12-31-2022, 06:12 PM
  #183
Body In White
Body In White's Avatar
Hey Elliot, one thing to be aware of: the OEM carbon trim for the cup holder and small “triangle-ish” pieces on either side of the steering wheel had the carbon weave rotated 45 degrees to make “diamonds”. All the other carbon pieces are laid as “squares”. Additionally, it has a cup holder logo silk screened on the trim in the center, you can see an example here: https://bringatrailer.com/wp-content...364-scaled.jpg
The reason I mention this, DB Carbon isn’t able to silk screen the cup holder icon on the trim — I didn’t ask them if they could rotate the weave as it was a moot point without the logo. MACarbon will both rotate the weave and apply the icon if you ask them. I replaced all my cracked OEM carbon in my GT3 during a few years ago. I had MACarbon do the cup holder trim, and DB do everything else. It all matched perfectly.
Old 12-31-2022, 06:22 PM
  #184
Elliotw44
Elliotw44's Avatar
Oh Thanks! I didn't know the trim had the carbon weave rotated 45 degrees on just the pieces on the dashboard. Personally I actually like the logoless cup holder look but always good to call it out. I'll send an email over to DBCarbon to see about the rotation.
Edit: Contacted DBCarbon and they can do the rotation.
Old 12-31-2022, 07:37 PM
  #185
Wonderdan
Wonderdan's Avatar
Received 1,189 Likes on 639 Posts
Ya mine is pulling away from the car now and will be replaced eventually but I’ve been married to my build sheet other than my headers and carbon Dundon… $900 is just crazy. I’m just not sure when Porsche will stop making OEM parts to know when I need these ordered by. After talking to Suncoast they have been cutting back on a lot of OEM 997 cosmetics, the bolsters are now a 6 month custom order.
Old 12-31-2022, 10:39 PM
  #186
Body In White
Last year, I did a cosmetic refresh on a 996 GT3 that I picked up during COVID (covered in this thread). It was a logistical nightmare acquiring all the parts — many of which I was told were no longer available, only to have them show up 8 months later with parts that were clearly warehoused somewhere in Germany for 10-15 years (storage dust included). It spooked me a bit with regard to the 997 cars. I’ve started to jump on some of the unobtainium parts and storing them for an eventual refresh.
Old 01-01-2023, 12:06 PM
  #187
Wonderdan
Wonderdan's Avatar
im not one to bet against stuff but I think I’ll pick up some of the little stuff I want fixed. The thing about buying OEM carbon is if it’s the same exact part from the same manufacturer won’t it just warp again…DBcarbon had a lifetime warranty, ofc it’s a small business so who knows what that means.
Old 01-01-2023, 01:27 PM
  #188
vma1788
vma1788's Avatar
I've been enjoying the additional conform and easier exiting the seat for street usage. For track days I play on tacking my OEM set with me and swapping. The only permanent solution I know for lowering the 997 buckets is available from Cantrell. They have an adjustable seat bracket which goes lower then stock. Lowest setting is 1.25 inch drop. Product here: https://cantrellmotorsport.com/produ...side-mounts-2/
Thanks for the info. I've read mixed reviews on the Cantrell lowering brackets so i figured the easiest and best fitting situation would be a thinner pad. Likely will go custom on retain the stock unit as well.
To further the glove box trim, mine is also pulling away or sagging and it bugs the hell out of me. So a cupholder will be a welcomed addition. May try to repair my trim before sticking it in storage as i've had no luck sourcing a oem trim piece.
Old 01-01-2023, 08:39 PM
  #189
ilko
Agent Orange
ilko's Avatar
Regarding the cushions… I just removed the foam that my butt rests on the bucket seat in my 987 Spyder and replaced it with thinner foam. Now I sit a whole inch lower.
Original foam:
Compared to replacement foam:
Replacement foam installed:
Elliotw44 (01-01-2023)
Old 01-01-2023, 09:59 PM
  #190
Elliotw44
Elliotw44's Avatar
My friend (@gjenk) has the Cantrell lowering bracket on his GT2 Buckets and they are great for him he is a taller driver and has the steering wheel extension as well. I sat in the buckets with the lowering brackets and it makes a huge difference.
Old 01-05-2023, 05:23 PM
  #191
Elliotw44
Elliotw44's Avatar
Cantrell 997 Rollcage getting finished up before shark blue treatment
The following 2 users liked this post by Elliotw44:
Breakthru (01-07-2023), Full Boost (01-07-2023)
Old 01-10-2023, 04:40 PM
  #192
Elliotw44
Elliotw44's Avatar
Sometimes I feel bad about how much I love this car! lol
View this post on Instagram
The following 5 users liked this post by Elliotw44:
Breakthru (02-28-2023), brontosaurus (01-12-2023), escreation (01-11-2023), SupraSaiyan (01-10-2023), Wonderdan (01-10-2023)
Old 01-15-2023, 06:46 AM
  #193
fayraree
fayraree's Avatar
Awesome thread! Inspired me to do my own! I love lightwerkz, right in my backyard in NJ. They did my 4runner all up and now will be taking care of my 7.2 GT3 as well. They plan on doing a video install of the new morimoto 992 retrofit lights. Also felt your pain about the LED side markers, lol. I was lucky with my narrow body that the Diode Dynamics smoked markers matched my black paint perfectly and fit nicely. Will update pics in my journal soon!
Elliotw44 (01-15-2023)
Old 01-23-2023, 01:12 AM
  #194
Elliotw44
Elliotw44's Avatar
What's the best 997 angle? Front or back?
Steve Theodore (01-23-2023)
Old 01-23-2023, 01:50 AM
  #195
Steve Theodore
Steve Theodore's Avatar
I cannot decide so I will cast my very biased vote for BOTH!
Elliotw44 (01-23-2023)
Quick Reply: Elliot's 7.2GT3RS Journal
