Elliot's 7.2GT3RS Journal
#166
4.0 Winglets & Canards painted Shark Blue to match. Installed the 4.0 winglets and they look great on the salter aero uprights. The 4.0 canards are waiting. I know a 4.0 that is going to help me build a template for correct placement.
#167
You did paint not powder right on these parts?
#169
Pick up my car today after an extensive winter maintenance session. ST Carbon rotors and Guard Diff(40/60) plus full fluids and post track season inspection. The 4.0 Canards installed as well. Haven't given the brakes a good test yet but initial thoughts is stiffer brake pedal and worked well on a rainy Seattle Winter Day. The Guard Diff's aggressive lock up was noticeable on acceleration the tail wanted to kick out. Put a smile on my face as I giggled. Excited to get some more experience with in on the track and to feel the lock up on deceleration.
The following 3 users liked this post by Elliotw44:
#170
Elliotw44 (12-27-2022)
#172
Did you track your car before adding the taller wing stands? If so was there a noticeable difference in the dynamics? I like the low wing but would love some rearview visibility however I don't want anymore rear downforce//understeer.
Been enjoying your build and seeing you rack on track time and miles. Keep up the good work!
#173
#175
Car is getting close to complete.
Upcoming plans for 2023
- Shark blue Cantrell rollcage
- DBCarbon interior pieces arriving in February
- Yellow seat belts and yellow door pulls
- Rewrap Steering Wheel
- 70% Xpel Tint
- 10 track days
- Rennsport VII
#176
did you end up ordering the carbon piece above the glovebox or just getting the one with cup holders?
#177
Below is my DBCarbon order. tried to keep it OEM+. Only one non-OEM piece in carbon. Big thanks to the members here for the help on the different pieces.
Side vents r+l (Options: Carbon black, finish highgloss +0% (OEM matching))
Center Vent (Options: Carbon black, finish highgloss +0% (OEM matching))
3 Cup holder trim pieces (Options: Carbon black, finish highgloss +0% (OEM matching))
Ignition surround(Options: Carbon black, finish highgloss +0% (OEM matching))
Middle Console (Options: Carbon black, finish highgloss +0% (OEM matching))
Ash-Tray (Options: Carbon black, finish highgloss +0% (OEM matching))
Wonderdan (12-31-2022)
#178
P1Design 997 GT2 bucket seat inserts arrived today
Noticeably more comfortable. But Noticeably higher in the seat. This makes exiting the seat easier. See the side by side of the bottom cushions OEM vs P1Design. OEM may feel better on track. Will be interesting to see how they break in.
Elliotw44 (12-31-2022)
#180
Nice list for 2023. Is that cupholder the entire unit or just the covers? My car is cupholder delete but i think i can spare the weight addition for the convenience.
Super bummer about the thickness of the seat cushions. I was actually considering seeing if i could find someone to make mine much thinner opposed to installing lowering seat brackets. When i track my car I run an alcantara Sparco cushion and the increased headroom is perfect. Would like a more permanent solution.
