7.1 GT3 RS wing adjustement
Hello friends. I have placed a 7.1 GT3 RS wing on my 7.1 GT3, but I do not know if the tilt can be adjusted. I would like some indication or a DIY. I have searched here and I have only read that it has 12º variation margin, but nothing clear for me. Thank you.
Yes its adjustable. Loosen the 2 torx fasteners on each side, T40 and T45 if I recall correctly (not sure why they used different sizes side by side!)
Matty
Matty
[font][font][QUOTE = matt33; 15960018] Sí, es ajustable. [/font][font]Afloje los 2 sujetadores torx de cada lado, T40 y T45 si recuerdo bien (¡no estoy seguro de por qué usaron diferentes tamaños de lado a lado!) [/font][/font]
[font][font]Matty [/ QUOTE][/font][/font]
Thanks, i will try.
Thanks, i will try.
Not to discourage you, but this is a very simple adjustment. If you're having difficulty with it I would try to find somebody local that can give you a and. The last thing you want is t lose a wing at speed!
It is done. Thank you very much to all. Actually, I wanted to know if there was any predetermined position or some kind of wedge like there is in the 996 GT3. The process to move it has no difficulty.
