997 TRW GT3 LCA front or rear fitment
Does anyone know if the 997 GT3 TRW LCA (JTC1190 & 1191) fit on either the front or rear? They are listed on the Summit Racing site as rear fitment. But from what Ive read the front and rear LCA are interchangeable. Is this correct? Anyone use these on the front of their car?
https://www.summitracing.com/parts/trw-jtc1190
These would be going on the front of a 997.2 C2S to gain around 2.0-2.5 degrees of negative camber up front.
Those TRW LCA (JTC1190 & 1191) are for the front (2 piece units so camber shims can be added)....the rear OEM units on a 997 GT3 mk1 and mk2 are 1 piece.
Cheers
Doug N
QUOTE=silvertoy;15875659]Does anyone know if the 997 GT3 TRW LCA (JTC1190 & 1191) fit on either the front or rear? They are listed on the Summit Racing site as rear fitment. But from what Ive read the front and rear LCA are interchangeable. Is this correct? Anyone use these on the front of their car?
These would be going on the front of a 997.2 C2S to gain around 2.0-2.5 degrees of negative camber up front.[/QUOTE]
Cheers
Doug N
The stock rears are in fact 1 piece, however, you can put 2 piece ones on. For instance the RSS Tarmac arms are the same for all 4 corners. The 2 piece in the back gives you adjustability beyond what the eccentric bolt can do.
