Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 997 GT2/GT3 Forum
Reload this Page >
Otto Car Club Porsche 997 GT3 RS with BBS E88, BBi Roll Bar, Recaro Seats
997 GT2/GT3 Forum
Old 05-07-2019, 03:09 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default Otto Car Club Porsche 997 GT3 RS with BBS E88, BBi Roll Bar, Recaro Seats
Otto Car Club Porsche 997 GT3 RS BBi Roll Bar & Recaro Seat Install
Recently, we track prepped this beautiful Silver Porsche 997 GT3 RS with BBS E88 for belonging to Eli Kogan from OTTO Car Club, a unique social club and storage facility for car collectors and enthusiasts in Arizona. We installed our our BBi Autosport StreetCup Roll Bar powder coated in Satin Black, Schroth GT3 Harnesses, and a Recaro Profi SPG racing seat mounted on our BBi Seat Base & Slider Kit to provide proper restraint and support. We finished it off by dialing in the suspension with our corner balance and alignment setup. Here are some pictures we would like to share!!!
BBi Autosport Porsche 996/997 Roll Bar
Features
  • Made from high strength seamless tubing (DOM) (1.5” x .120” main hoop & 1.5” x 0.95” rear hoops) for excellent strength to weight ratio
  • TIG welded and utilizes “X” braces on both front and rear sections for superior strength and rigidity
  • Mounts to front seat belt mounts and rear strut towers
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
  • Designed to work with stock or any aftermarket seats on the market
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other optional colors available
  • Designed to fit all 996 & 997 non-cabriolet models including the Carrera, Turbo, GT2, and GT3
  • Bolt-in installation requires no drilling and minimal carpet trimming
  • Compatible with factory Bose subwoofer
  • Made in USA
- [email protected]
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: [email protected] Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
BBiAutosport is offline
Old 05-08-2019, 02:18 PM
BBiAutosport
Basic Sponsor
The RECARO Profi (FiA) racing seat provides the best starting position for racers seeking to compete for podium places. The Profi's ergonomic S shaped shell forms to the back and the he "built-in" lumbar support provides structured support for the lower back that protects against spinal compression in high impact accidents. Combined with high quality foam the seat is outstandingly comfortable. The bolsters and deep seat cushion pocket cradle your body. The seat holds you firmly in place preventing the fatigue and discomfort caused by unwanted movement during aggressive driving maneuvers. Available in 2 sizes, the Profi SPG XL is 35mm Wider than the normal Profi SPG.
  • FIA Certified and Crash Tested
  • RECARO Proprietary Ergonomics
  • RECARO High Integrity Comfort Shell - Fiberglass
  • Larger Height and Width - Fiberglass Shell
  • Aggressive Thigh & Torso Bolstering
  • Lumbar Cushions
  • Shock-absorbing foam
  • RECARO Friction Grip at Shoulders
  • Screw Mounted Panels at Belt Slots
  • Flame Retardant Upholstery
  • Long Lasting High Quality Cover
  • High Quality Durable Foam
  • Suitable for 4,5, or 6 Point Harness
Old 05-09-2019, 06:38 PM
BBiAutosport
Basic Sponsor
BBi Autosport Porsche Seat Base and Slider Kit
Compatible with all contemporary Porsche models, the BBi Seat Base Kit directly bolts in to the factory mount location and offers wide range of adjustment options to fit most FIA and SFI approved seat models. The base kit also features an integrated 5 and 6 point sub belt mounting location as well as removable brackets to mount the lap belts. To maximize strength and stiffness, the kit was CAD designed and CNC laser cut and formed from one piece of .125” (1/8”) carbon steel. All bases are powder coated with a wrinkle black base and satin black sides.
Features:
  • Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
  • Multi way adjustability
  • High strength sliders, mounts to base with 4 bolts per slider
  • Integrated 5 and 6 point sub belt mounting locations
  • Removable Brackets to mount lap belts
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • Fits all major FIA/SFI approved seats up to 17”
  • 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
  • No modifications to vehicle or any seat mount components are required for installation
  • Uniquely designed for Porsche vehicles for the best possible fitment
  • Mounts to factory bolt locations with precise factory fitment
  • Fits Porsche 996/997/991/986/987/981/718 models
Recaro Seat Installed
Old 05-10-2019, 02:08 AM
mooty
GT3 player par excellence
mooty's Avatar
tell Eli to not mess around
that seat is for kids
get P1300
mooty is offline
Old 05-10-2019, 12:50 PM
911mhawk
911mhawk's Avatar
get P1300
Any of you regularly run a Halo on the street?
I've been thinking of ditching my elephant ears for something more but still love to street the car regularly during dry weather.
911mhawk is offline
Old 05-10-2019, 01:51 PM
BBiAutosport
Basic Sponsor
Old 05-11-2019, 02:33 AM
mooty
mooty's Avatar
yes I do
DD one for 40000 miles
mooty is offline
Old 05-16-2019, 02:25 PM
ekoges
ekoges's Avatar
get P1300
compared to your old age, guess I'm a kid.
one bucket seat for me, one comfy seat for the queen
ekoges is offline
Old 05-16-2019, 02:33 PM
jasonturbo
jasonturbo's Avatar
Great pic w/ the doggo.
jasonturbo is offline
Old 05-16-2019, 11:09 PM
idk_alex
User
idk_alex's Avatar
That looks so good its painful
idk_alex is online now
Old 05-17-2019, 08:35 AM
//steve\\
User
This car is one of my absolute favorites. I still prefer the 997.1 to the .2.
//steve\\ is offline
Old 06-07-2019, 04:44 PM
BBiAutosport
Basic Sponsor
Corner Balance and Alignment
Ready for Delivery
- [email protected]
Old 06-07-2019, 09:43 PM
luv2race
luv2race's Avatar
Looks great
luv2race is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
