997 GT2/GT3 Forum 2005-2012
What would you guys pay for a higher mileage 997 GT2?
Old 03-10-2019, 06:06 PM
Steve Theodore
Steve Theodore's Avatar
Originally Posted by CT944
Did the car originally come with the carbon buckets? Lots of GT2s I’ve seen have the regular sport seats. If you really want the PCCB rotors for originality, you can take your time to source a used set after you get the car, no rush. At 40k miles and needing a few maintenance items, it’s a deal. Most 997 GT2s are listed for $175k+, some with 20k+ miles. That car new was likely $205k. I’d run.....to go buy it assuming no CarFax issues. If you aren’t interested let me know.
$224k for this one with 9k miles. https://www.porscheofcoloradosprings...co-id-28380489
I'm sure most of you are paying attention, but GT2 (997) inventory moves at a glacial pace from what I've been seeing. Therefore we have to assume either demand is rather low or pricing is perceived too high. Many of the cars listed at $175-$190 just seem to sit endlessly on the market. I believe this car came equipped without carbon sport buckets, and so it's only the brake rotors that have been 'downgraded'. I'd like to keep the car at least a bit of a secret for the time being as it is not easy getting details out of the seller...but I'm trying. There are other challenges I didn't mention with this car, including re-importing it to the USA.
Originally Posted by Bxstr
Finding a set of carbon buckets for $6-7k should not be very difficult. I would go for it if that is the one thing that bothers you.
The seats, brake rotors, and exterior paint color are all not to my liking. The fact that it's a 997 GT2 available in this price range is very much to my liking, and possibly something I won't find again.
Old 03-10-2019, 06:25 PM
CT944
CT944's Avatar
I had a chance to buy this black/black 2009 GT2 from Sloan 5 or so years ago for $128k. It came in on trade when I was there looking at a white 1800 mile 996 GT2. Had 14k miles on it. I didn’t love the steering wheel, seats or color, but looking back it was a very big missed opportunity.
http://www.sloanmotorcars.com/curren...k-13503-miles/
Old 03-10-2019, 06:55 PM
Steve Theodore
From what I can tell, the car I'm looking at is similar to that example you pointed out, but with the brake discs changed out and obviously higher mileage. It has the 2008 PCM of course, not the coveted 2009 version. Thanks for the reference price point btw, as I wasn't sure what this car would be worth 5 years ago.
Old 03-11-2019, 12:05 AM
chiffonade
chiffonade's Avatar
steve theodore from the supraforums?
my only question would be where did the pccb's go? if they were replaced because the car was heavily tracked then i would also ensure that the clutch, suspension/bushings, wheel bearings, and motor mounts are all in good condition. everything should be smooth and firm. also look at the calipers for wear. if the paint is cracked they may need a rebuild.
my 997 gt3 needed a clutch at 25k due to track work, not due to worn surface but because of a broken fork and/or bearing.
$139k seems okay given: no pccb's, no seats, 40k clutch, probably needs plugs + 2 year maintenance, higher mileage. also check DME obviously.... but it's also a pretty good price for a GT2 and these things are all fixable with one trip to the shop.
Old 03-11-2019, 09:19 AM
Steve Theodore
Yes, same Steve you are referring to. I bought my first Porsche in 2009 and have never been without one. I do not know the reason for the missing PCCBs but I will make it a point to find out why they were removed. As my own GT3 RS has PCCBs that have even more mileage on them I'm certainly curious about them. Thanks for your thoughts on the matter.
Old 03-11-2019, 09:25 AM
Jon H
Jon H's Avatar
A few other item's to consider if you buy it -
Clutch kit (4.0L) - $2,200.
New motor mounts - $1,300.
Replace all hoses, gaskets, etc - $1,300
H2O pump, T-stat, coolant tank - $900
F & R seals - $400
Have coolant tubes been pinned / welded and have elbows to oil cooler been replace with metal?
Old 03-11-2019, 09:30 AM
993GT
993GT's Avatar
^ if it needs it, take advantage of the exchange rate while it's up here
think I know which car we're referring too, it may have been a Rennlister's before
Old 03-11-2019, 10:18 AM
CT944
CT944's Avatar
My old 2009 Cayenne Turbo S had PCCBs and after 85k miles, all 4 rotors were 'like new' according to the Porsche dealer and only required new brake pads, which were about 50% worn. The Cayenne is a heavy SUV, so the PCCBs are very durable.
Old 03-11-2019, 10:48 AM
gt2-josh
gt2-josh's Avatar
The story is it has tons of miles and the original brakes are missing plus I don't recall having to order the GT2 seats in my GT2. It's missing really important stuff and has huge miles. And the idea of just going out and buying PCCBs and buckets doesn't change the story. Plus you'll find out quickly you should have bought the right car in the first place. There aren't enough buyers of GT2s to make a liquid market. You will never be able to sell that thing. I've owned four GT2s and I've known other people with multiple GT2s. I have real world experience with this situation. JBO PS The people saying just go get PCCBs and seats don't realize the cost will skew the perceived value of the car even more. Don't listen to that nonsense. The car will be great fun but it will be impossible to sell. The entire GT2 market is stagnant right now...
Old 03-11-2019, 11:00 AM
CT944
CT944's Avatar
I don't think 40k is 'tons of miles'. If the goal is just maximizing resale value, then clearly this isn't the car, but the OP is looking for a driver.
Old 03-11-2019, 11:07 AM
gt2-josh
gt2-josh's Avatar
It's probably one of the highest mileage 997 GT2s period. So it does have a ton of miles. My first comment is it will be totally reliable. My second thread was about resale value. This car is priced too high and it will be insanely difficult to sell later. That is fact. And I believe having bought and sold four of them I have some experience with the market. Josh
Old 03-11-2019, 11:15 AM
go-ran
go-ran's Avatar
The car was advertised here aswell. Yes it might have some missing parts etc but id say the price reflects it and its on you to negotiate more. if buying the GT2 also factor a rear diff and clutch upgrade because the GT2's wear em out quick.
Old 03-11-2019, 11:19 AM
CT944
CT944's Avatar
How much do you think it's worth if $139k is too high?
Old 03-11-2019, 11:20 AM
993GT
993GT's Avatar
there's a few out there with higher mileage... mileage is no concern for a driver, beside the diff/clutch upgrading don't see mileage being any issue... my lil old 6GT2 is just under 140k km driven hard with no issues
Old 03-11-2019, 11:22 AM
993GT
993GT's Avatar
iirc the seats were a choice, comfort 'sport' vs folding buckets
Quick Reply: What would you guys pay for a higher mileage 997 GT2?
