997 GT2/GT3 Forum 2005-2012
Porsche 997.1 GT3 BBi Roll Bar & Cobra Racing IMOLA PRO-FIT Seat Install
Old 01-21-2019, 08:59 PM
BBiAutosport
Basic Sponsor
BBiAutosport's Avatar
Default Porsche 997.1 GT3 BBi Roll Bar & Cobra Racing IMOLA PRO-FIT Seat Install
Attachment 1344394
To provide additional protection and proper restraint for weekend track days, we installed our BBi Autosport StreetCup Roll Bar into Mike's Porsche 997.1 GT3 along wit Cobra Racing IMOLA PRO-FIT racing seats mounted on our BBi Seat Base Kit. Here are some that we would like to share below.
Upgrades & Services Performed:
Safety
  • BBi 996/997 StreetCup Bolt-In Roll Bar
  • BBi Seat Base & Slider Kit
  • Cobra Racing IMOLA PRO-FIT
  • Schroth Profi II 6 Point Flexi-Belt Camlock Harness Set
BBi StreetCup 996 997 Roll Bar
Key Features
  • Made from high strength seamless tubing (DOM) (1.5” x .120” main hoop & 1.5” x 0.95” rear hoops) for excellent strength to weight ratio
  • TIG welded and utilizes “X” braces on both front and rear sections for superior strength and rigidity
  • Mounts to front seat belt mounts and rear strut towers
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
  • Designed to work with stock or any aftermarket seats on the market
  • Can be used with stock seat belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other optional colors available
  • Designed to fit all 996 & 997 non-cabriolet models including the Carrera, Turbo, GT2, and GT3
  • Bolt-in installation requires no drilling and minimal carpet trimming
  • Compatible with factory Bose subwoofer
  • Made in USA
[SIZE="5"]Cobra Suzuka Pro Seats[/SIZE]
Cobra Imola Pro-Fit Kevlar race seat couples an unrestricted driving position (for easier ingress and egress) with the added strength and weight savings of Kevlar construction with full HANS® compatibility. The Cobra Imola Pro-Fit is covered in FIA compliant fire retardant, durable, and breathable 'Spacer' fabric incorporating anti-wear Suede-Tec patches at the arm and shoulder areas gives the Imola Pro-Fit hard-wearing good looks comfort, cooling, and safety.An unique Kevlar construction makes the Imola Pro-Fit seat infinitely stronger and 30% lighter than similar fiberglass seats at an ENTRY LEVEL PRICE below that of similar designed fiberglass seats. The Cobra Imola Pro-Fit seat is an excellent blend of composite performance and value.
Features:
  • Side mounted only
  • Available in standard or GT (+30mm width)
  • Unique PRO-FIT custom padding system
  • Full 6 Point harness facility
  • Hans compatible
  • Breathable Spacer fabric
  • Optional Outlast cooling system
  • Supplied with high tensile bolts pre-installed
  • Integrated wear patches
[SIZE="6"]BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat [/SIZE]
The BBi Autosport race spec seat mounts are a direct bolt in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powdercoated with a wrinkle black base and satin black sides.
Features
  • Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
  • Multi way adjustability
  • High strength sliders, mounts to base with 4 bolts per slider
  • Integrated 5 and 6 point sub belt mounting locations
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • No modifications to vehicle or any seat mount components are required for installation
  • Uniquely designed for Porsche vehicles for the best possible fitment
  • Mounts to factory bolt locations with precise factory fitment
  • Fits all major FIA/SFI approved seats up to 17”
  • 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
  • 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Imola Seats Mounted on our BBi Seat Base & Slider Kit
Installed in Car
- Jerry@BBiAutosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Quick Reply: Porsche 997.1 GT3 BBi Roll Bar & Cobra Racing IMOLA PRO-FIT Seat Install
