997 GT2/GT3 Forum
Sticky/ reluctant starter
Old 01-07-2019, 12:06 AM
Modena 1
User
Default Sticky/ reluctant starter
My car has become increasingly difficult to reliably start. Sometimes it's fine. others it's click click click try again click as i freak out that I will
Have to leave the car at a gas station.
Sticky starter solenoid? Is this common? My 997.1 gt3 never had an issue. My current 997.2 rs used to crank faster than my .1 did and start faster. Now it's finicky. I changed the battery already and didn't make a difference and i leave it on a Porsche tender.
Feedback appreciated before I spend money.
Ty
Modena 1 is offline
Old 01-07-2019, 01:03 AM
grizfish
grizfish's Avatar
Most likely a loose ground somewhere in the starter circuit. Humidity will have an effect on a bad connection, possibly explaining the intermittent problem.
I would check all the connections between the battery, frame ground, and starter. Remove each connector and use some emery cloth to roughen up the surfaces before re-connection.
Also, solenoid power cable, solenoid, starter, ignition switch, and all related wires.
grizfish is offline
Old 01-07-2019, 11:06 AM
jackb911
jackb911's Avatar
Modena 1, my GT3 had the exact same symptoms as yours. The loose ground that grizfish described very well could be the culprit, but if that doesn't work, it could be an intermittent clutch pedal ignition lock switch. ( https://www.suncoastparts.com/product/SKU9XXCPS.html ) I temporarily replaced mine with a jumper wire which worked for a short time but the problem ended up being the starter - likely the solenoid. I had my starter rebuilt at a local Bosch approved shop and now all is well. Yes, the starter problem seems to be pretty common as these cars get older.
The ignition switch on 997's is also prone to failure but I doubt there will be a "click click" if that happens.
There are DIY threads on here and on Pelican for all the above if self-maintaining is your thing.
jackb911 is offline
Old 01-07-2019, 03:13 PM
D-Uber Cars
User
D-Uber Cars's Avatar
Ty,
Your description is exactly the same symptoms that my 07 997.1 RS exhibited. Checked all electrical connections and also followed jackb911's process. In the end, the starter was on it's way out. Replaced, no issues.
Good luck.
D-Uber Cars is offline
Old 01-08-2019, 10:46 PM
hardrs
User
My 2010 997.2 GT3 RS had the same problem. Apparently it's common. My starter was replaced under warranty in 2018 with a newer, more robust unit. There's a discernible difference in how quickly it fires up with the new starter.
hardrs is offline
Old 01-09-2019, 11:32 AM
JB911
JB911's Avatar
Try cleaning contacts and tightening them at the starter-and of course make sure your battery isn't part of the problem-if needed, replace it.
https://rennlist.com/forums/997-gt2-...ter-click.html
JB911 is offline
Old 01-09-2019, 12:41 PM
PDL996
PDL996's Avatar
My 2010 997.2GT3 exhibits the same problem! Replaced the battery, a week later, back to the dreaded click!
Is there a DIY on replacing the starter in a GT3? I would probably have a local shop replace it!
PDL996 is offline
Old 01-09-2019, 03:43 PM
jackb911
jackb911's Avatar
When I replaced my starter I couldn't find a DIY for the 997 GT3. This was as close as I could find. Note that the Mezger GT3 engine has the starter located in the same location as the earlier air-cooled 911's. "Regular" 997's require access via the engine compartment,
https://www.pelicanparts.com/techart...er_install.htm
The access is probably tighter on the 997 GT3 but it basically requires disconnecting the wires and the ground strap from the starter and the two bolts that attach the starter to the crankcase. Contrary to what others have reported, it is not necessary to un-attach the inner CV joint on the right rear axle as the starter will come out vertically after a bit of fiddling. Re-installation is the opposite of removal but make sure to clean the wiring and ground contact points. The top starter bolt is a bit dicey to reinstall, just install the lower one first and do not tighten fully until both bolts are in place,.
If you have access to a lift, the procedure is pretty easy. At the time I did not have one (I do now), just a pair of good jackstands, and the process was not as much fun as it otherwise could have been. By the way, if you remove the right rear wheel like I didn't do, you will be happier.
Also, if you buy a new starter, get the Bosch, not the one that comes in the Porsche box. It is the exact same starter - same part number. The only difference is the one that comes in the Porsche box carries the typical Porsche Tax. Examples from Pelican Parts:
BOSCH - https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&description=starter $396.50 (available for less elsewhere...)
PORSCHE - https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&description=starter $1,438.75
jackb911 is offline
Old 01-09-2019, 06:21 PM
JB911
JB911's Avatar
If you look at my thread you can see that I could have easily kept going to remove the starter(11mm deep socket needed)
You probably only need to tighten the cables-
JB911 is offline
Old 01-10-2019, 11:57 AM
PDL996
PDL996's Avatar
Jackb911 and JB911,
Thank you for your swift replies and insight in regards to this issue!
As always, i will apply the simplest methods first and go from there!
Have a great day and thank you again!
Regards,
Paul
PDL996 is offline
Old 01-11-2019, 11:01 AM
andrewgt3
User
andrewgt3's Avatar
In the meantime, try banging on the starter with a hammer. Not too hard, just a few knocks. This has worked for me to get cars started with starters that are dead or dying.
andrewgt3 is offline
Old 01-12-2019, 04:55 PM
khooni
User
khooni's Avatar
Yeah replace the starter. Then it will be like new again
khooni is offline
Old 01-13-2019, 09:22 PM
sfo
User
sfo is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
