RSS TOP SELLER | 312 - Adjustable Rear Toe Steer Kit | Back In Stock!
RSS TOP SELLER | 312 - Adjustable Rear Toe Steer Kit (Fits: 986, 996, 987, 997 all) | Back In Stock!
RSS Direct Link: http://roadsportsupply.com/312-rear-...6-987-997-all/
The RSS Adjustable Rear Toe Steer Kit - designed for Porsche models that have been lowered or run aggressive alignment specs.
- Winner of Multiple Motorsport Championships (Rolex Grand-Am, FiA Rallye, and Pirelli World Challenge)
- Allows for proper alignment of rear toe angle on lowered vehicles.
- Extends tire life and minimizes suspension geometry change in the rear of vehicle by eliminating rubber bushing deflection.
- Adjustment is made at the Toe Steer Arm (Lengthening or Shortening Arm vs Rotating O.E. Eccentric Adjuster Bolt).
- Height adjustable outer arm design, allows for rear bump steer adjustment on 996-997.
- Kit improves handling and feedback. - Toe Steer Kit can be used in conjunction with O.E. Eccentric Bolts (however they become redundant and a weak link).
- RSS recommends the use of the 333 Locking Plate kit which replaces the Eccentric Bolts, and prevent the rear toe settings from getting bumped out of alignment during aggressive driving on track (taking curbs) or driving on rough roads.
AVAILABLE FOR ALL PORSCHE® 986, 996, 987 & 997 MODELS INCLUDING TURBO & GT3/GT3RS.For optional Locking Plate Kit, see our Part #333. For Front Toe/Bump Steer Kit, see our Part #370.
I have these as part of my RSS Tarmac Series kit, and they are worth the cost. All told, it was nearly $3200 (including semi-solid motor mounts) plus another $1000 to install the entire Tarmac Series kit (Porsche dealer), but it was the best money spent yet. Surprisingly, the ride actually became more compliant, and I am thinking it has to do with the lack of binding by the rubber bushings that have now been eliminated. An increase in steering precision and 'tightness' also were noticeable (to me and the Porsche Master Tech). These are worth considering.
Thanks Doc_porsche
Appreciate the product feedback HarmonyJim!
RSS TOP SELLER 312 - Adjustable Rear Toe Steer Kit (Fits: 986, 996, 987, 997 all) Back In Stock!
