Rough idle and hesitation during cruising
Folks,
I experiencing a rough idle and during low speeds and cruising feel hesitation from the engine. Under load the car feels fine. Plugs and coils are fairly new in the car. I have a durametric and looked at misfires, since this is what it sounds to me during idle. I have no CEL. At cold start I see multiple misfires in all cylinders. There is a misfire counter which goes into the thousands. Is this normal? Anybody able to guide me on what I should read out and what is normal and abnormal?
Thank you very much!
Thank you for your response. The battery should not be too old. Also, if I am not driving the car I always put it on the trickle charger. I did not look at the MAF but measured the voltage at idle which was around 1V. Hope I am not wrong but it seemed to be in the range it should be. Vacuum leak, yes, maybe. How to test for that? If I am not mistaken there should be crank case vacuum. When I take the oil cap off at idle I cannot feel anything. What negative pressure should I expect at the oil filler cap? A range of values would be great. Does anybody have insight?
Checked the battery. Seems to be ok. I would greatly appreciate if someone could check with their durametric what misfire data they collect. Also if anybody has an idea on what other data I should take a look at. Thank you very much!
Thanks for the suggestions. It’s not bad gas. Filled it already twice and it did not change. With hoses, do you refer to the vacuum hoses? Any idea what vacuum I should expect? Also still looking for the crankcase vacuum. Nobody aware of what range it should be in or if it can be felt when the oil cap
is removed during idle?
Thank you very much in advance! Could you also please check if you feel a vacuum when you take off the oil cap when at idle. This would really help.
MAF
Dying fuel pump
You already did the main 2 electrical things
My car was doing a few weird things, when 'lugging' engine would misfire and pull back timing. I replaced all plugs & coils, no change. Replaced MAF. It was MAF.
Codes didn't indicate that directly. Just was getting misfires.
Dying fuel pump
MAF
Dying fuel pump
Dying fuel pump
Oh one thing... I have a fabspeed catback max flow. Big ham style mufflers are eliminated. The solenoid that is used to open the exhaust flaps is capped on one port and disconnect from the power. The lower port of the solenoid is open. Is that supposed to be the case? Did something fall off? Thanks!!!
Cap the solenoid bottom port.Assuming you are talking about the solenoid near the PS fluid tank. Right side of motor as you're looking at it from top.
I dunno, I have a durametric but just swapped the MAF. Got the Bosch equivalent part from RM European. Wasn't very $.
https://www.rmeuropean.com/Products/...FG14-V961.aspx
