Brake Knockback/Brake Kit Question
Hoping for any input on brake pad knock back solutions. Tracking the car is really unsettling not having a consistent brake pedal. Have searched and there are a couple threads, replace master cylinder, rebuild calipers or just replace system with brake kit. Most threads end with no definitive solution.
Looking for any real world input from actual solutions. Have seen a couple of Stoptech kits come up for sale but not much feedback and zero on Brembo system.
https://rennlist.com/forums/997-gt2-...e-track-2.html
https://rennlist.com/forums/997-gt2-...brake-kit.html
How old are your hubs and bearings?
i get zero noticeable knock on my car
i use Brembo 380mm type5 hd rotors, full floating with aluminum hats, stock calipers that are refreshed regularly and reaches tecqhnology pads.
Hubs were replaced last summer as didn’t know last time they were done. Didn’t change braking characteristics.
Tom, GT3s have a brake priming feature where the car moves the brakes to the rotor surface when the accelerator pedal is lifted abruptly from WOT. So knockback should not be an issue on these cars if everything is operating correctly. I'd have your brake system inspected to be sure everything is working properly. The biggest question is if you are sure the problem is knockback. Could be rotor/pad material combo, rebedding needed, different fluid, sticking pistons etc.
Endless RF 650 fluid flush
First try flushing your brake system with Endless RF650 brake fluid.....this WILL give you a more consistent pedal when things get very hot at the track.
Best regards,
Doug N
You may remember that last corner at Autobahn last summer when I ran up your tail into the corner. That was when I called it quits for the day, way too much drama.
Can you describe in more detail what you are experiencing? What tires do you run, and what brake fluid / pads / rotors? Also can you describe your braking profile. And, what is your alignment, specifically rake? Lastly, what diff do you have?
recap the original problem, the brake pedal would start to get "long" on the track. As the brakes got hot, it took more pedal travel to get braking as a track session progressed. A quick tap on the brakes before hard braking would temporarily restore the brakes to normal, so that became my braking routine on the track.
Tires - Michelin Super Sport & currently Michelin 4s
Fluid - Castrol SRF
Pads - Pagid and currently Performance Friction 08 or 11 can’t remember which in file at home
Rotors - AP racing
Alignment would need to check file
Differential was rebuilt by previous owners shop less than 10k ago
To me that sounds exactly like overheated brakes and not knock back.
Does anyone think he may be falling victim to ABS Ice Mode? Tom, are you familiar with this?
General thread:
https://rennlist.com/forums/997-gt2-...ly-got-me.html
One of the better posts (#293) from that thread:
https://rennlist.com/forums/997-gt2-...l#post14192855
General thread:
General thread:
General thread:
