997 GT2/GT3 Forum 2005-2012
HELP! Centerlock refuses to come off.
Old 01-26-2018, 12:05 AM
WantA997
WantA997's Avatar
Unhappy HELP! Centerlock refuses to come off.
Swapping my wheels and have run to this most unfortunate situation. The front passenger centerlock refuses to come loose. Have tried applying 440nm, 600nm... nada.
I suspect the previous owner did not apply any/enough grease when re-mounting the wheels before he sold the car to me.
Has anyone had this issue before? How did you resolve it?
Thanks in advance!
Old 01-26-2018, 12:16 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
1 front or rear, front is usually the issue?
2 is the czar off the ground?
3 turn ignition on, have a STRONG HUMAN (not the stupid brake depressor many like to use), step on the brake like his life depended on it. and untorque it. how big are you. one time i had some issues getting it off. i am not small and fairly atheletic. then my wt lifting buddy 250# pulled it, came off no problem..
lack of grease should not be that big an issue for untorquing it. it is a safety issue however, if no grease used.
Old 01-26-2018, 03:53 PM
shotor
shotor's Avatar
I'm on the lighter side and always have problems taking one of them off.
Get a long tube to extend the length of your breaker bar. Got a 5' aluminum tube from Home Depot. Have found that jumping on it doesn't seem to work as well as continuous load.
I have one of those brake depressors and it works, till it doesn't. Another human is needed on the wheels that are really stuck.
Old 01-26-2018, 06:25 PM
audipwr1
audipwr1's Avatar
10ft bar it'll come loose
Old 01-26-2018, 06:34 PM
FRP||
FRP||'s Avatar
If you were near I'd lend a hand with my torque multiplier as they're very handy for these kinds of issues. If you don't have a beefcake friend this could be a decent alternative.
One other option: Drive around a bit while dragging the brakes / use a heat gun to get some heat into the wheel/hub. Fasteners are easier to remove when hot as the materials expand and reduce thread pressure.
Old 01-26-2018, 06:35 PM
audipwr1
audipwr1's Avatar
Don't put heat on center lock nut
Old 01-26-2018, 06:43 PM
Saru385
Saru385's Avatar
1. drive car to track
2. drive around track until center lock and/or coolant lines fail
Old 01-26-2018, 06:46 PM
FRP||
FRP||'s Avatar
Some heat. Not a ton.
No blow torch
Old 01-26-2018, 06:47 PM
steve porter
steve porter's Avatar
Leave the car on the ground to to crack it a bit,that way more force will go directly to loosening rather than deflecting through suspension arms, bushings etc, but lift it before loosening to not damage wheels
Old 01-26-2018, 07:22 PM
Speedster911
Speedster911's Avatar
No blow torch
NO HEAT!!
- as others have stated- have someone depress the brakes for you. I had to add a 4 FT " extension" to my breaker bar when I had this issue the first time I attempted to remove my wheels. I think original owner didn't have enough grease on them so I replaced the center locks after the difficulty, I make sure I put ample grease on now and have never had an issue again
Old 01-26-2018, 08:05 PM
WantA997
WantA997's Avatar
This did the trick. New wheels are now on.
I appreciate all the responses from everyone!
Old 01-27-2018, 12:50 PM
eeterp
eeterp's Avatar
Beautiful wheels!
Old 01-27-2018, 04:50 PM
sin911
sin911's Avatar
Now we need a full shot of the car with the wheels
Old 01-27-2018, 05:08 PM
FRP||
FRP||'s Avatar
Originally Posted by Speedster911
NO HEAT!! [...]
This is amusing. What do you think happens on canyon runs or the track? Lots of heat all around on all these components.
If the PO didn't grease the mechanism correctly the mechanism was actually potentially under torqued despite needing lots of torque to remove. Heat removes some of this force and decreases the likelihood of galling, stripping, deformation, etc.
Pretty amusing to see the all caps. I guess we're all at various levels of mechanical knowledge
Old 01-28-2018, 12:21 AM
boostedt0y
boostedt0y's Avatar
looking good. Love my gold e07
Quick Reply: HELP! Centerlock refuses to come off.
