Seat school......
#32
FYI there are two sizes of CGT bucket seats. I-codes 386 & 387 are size XT which fits larger folks quite comfortably.
#34
#35
I did not know this either. And it explains a lot. I don't consider myself particularly large in any direction (6'0", 200# give or take), but I graduated from 34s to 36s a couple of years ago. Getting into a CGT seat was akin to slipping into ski boots for the first time after a long summer. I was afraid that parts of my anatomy were going to go to sleep - and I really don't want to experience that sensation in those parts. Yet I have friends who are wider than I am and are happy with their CGT seats.
I will concur with posts above regarding the 996 GT3 elephant ears - they are the most comfortable / most supportive Porsche seats as far as I am concerned. But they will likely make way for GT2 folding buckets for practicality / looks reasons...
#36
Part number at the bottom of the carbon bucket. The fourth set of double digits (ignore the last 3 characters here being the color code). .00/.01/.02 are the regular sized items; .03 is the larger size XT.
#37
Here is a comparo of the 3 seats I had: Spa, OEM 6GT3, OEM CGT-standard size
You can see how much wider the CGTs are on the waist, yet supper skinny in the shoulder area. I was swimming in those and the shoulder is so narrow that your shoulders are outside the seat and as a result the seat provides no real lateral support there. Due to the narrower waist and wider shoulder area, I found the 6GT3 seats better than the CGTs in both respects. The Spas really wrap and grip your shoulders with the rubber dotted pads there. If you compare the CGTs with a stock sofa seat they are great, compared to a race seat, not so much. Most people don't realize this unless they compare with other buckets back to back. Again, seats are highly subjective depending on your body shape and goals. Sort of like getting that perfect pair of jeans.. Try before you buy and be skeptical of internet recommendations. That's what I always tell people. Just my $0.02.
#39
Adjusting the lean of the CGT seats
i bought CGT perlons thanks to mootie’s heads up in 2010 but I could not stand the hight of sitting and the upright seat position( I am 6.2”). When wearing a helmet, it forced my head to tilt forward too much and either with or without helmet, it cut the tachometer in half in my field of vision. I went ahead and had the mounting brackets machined and now the position is perfect, much lower and properly tilted back. By the way, I have a 33” waist, athletic build and the seat fits perfectly except I would like more lumbar support. I can comfortably see the instruments with a cup steering wheel, I sit that low now.
Here is a link from my CGT post in 2010:
https://rennlist.com/forums/997-gt2-...ml#post8108206 #16
If anybody has a sugestion for adjustable lumbar support, I’d love to hear about it.
#40
If that doesn't work for you, maybe you could replace the lumbar pad with something larger, different shape, etc.
#41
Thanks for the info, could you possibly send a photo of the lumbar support pad you are talking about? I don‘t have additional lumbar support pads on my seats just the regular pad section attached to the seat via Velcro in the lower back area.
#42
I don't have a photo to hand, but I'll try and take one tomorrow for you. I should mention that I have the leather & alcantara seats, perhaps the perlon version didn't come with the lumbar pad for some reason?
#43
FYI you can buy lumbar support pads from any race shop. Usually made by recaro or sparco.
They come unbranded too:
for example.
https://www.ebsracing.com/product/lu...0aAjJCEALw_wcB
for example.
#44
FYI, I have a Recaro Carbon Fiber Pro Racer Hans for sale
The shape is similar to an SPA/SPG so you need to be fit or in shape to be comfortable in it; if you have a corvette body don't bother.
It's a full retention seat in that you won't have your neck snapped by a sideways impact
https://rennlist.com/forums/parts-ma...cing-seat.html
#45
for example.
for example.
