DIY Custom Side Splitters >>
Old 05-02-2017, 03:10 PM
  #31
platinum997
platinum997's Avatar
Originally Posted by Batman33
I'm wondering if profiling the edge with an electric router and a round over bit would make it look even better than it already does. One might also be able to shape it like, say, the splitter sold by Go Tuning that another poster referenced. Then again, maybe the ABS plastic material doesn't take well to either. Might be worth a try.
You can do anything you want with it.. just go slow on the cuts as it will melt.
Old 05-02-2017, 08:42 PM
  #32
platinum997
Originally Posted by Quadcammer
looks surprisingly good. any more daytime pics in the sunlight. Bit hard to see in the originals. thanks
There are some in the lets see your 997 post. If there are some specific shots you want... Let me know
Old 05-03-2017, 09:14 AM
  #33
Wolfk
Wolfk's Avatar
Under the rocker, just before the rear mudflap, there is a plastic fairing that slightly curves downward in profile view, is your splitter also following the curving downward?
Really appreciate your ingenuity.
Old 05-03-2017, 09:27 AM
  #34
platinum997
Yes.. that is connected to the mud flap. There are 2 screws on the bottom. I took one out, bought an extended screw (in the parts list on the 1st post) and used it to pull the splitter right up to it.
To your point, it slopes down just a bit in the back. I think it makes it flow better but you could remove that piece if you wanted.
Old 05-03-2017, 11:32 AM
  #35
Supermode
Supermode's Avatar
Looks like I have a new project to do this Spring. Thanks!
Old 05-03-2017, 02:58 PM
  #36
nwGTS
nwGTS's Avatar
Wouldn't the width need to be different for WB vs NB? And the WB side sills may not have the same hole alignment since that entire side of the car is a different welded piece on WB vs NB.
Old 05-03-2017, 03:27 PM
  #37
platinum997
I agree.. my guess is this will only work on a nb.
If someone has a wb in Columbus Ohio, we could try if you supply beer. The concept should be the same
Old 05-03-2017, 07:40 PM
  #38
slicky rick
slicky rick's Avatar
How I wish the car and me were at Columbus now. I'd be the first to bring beer at your doorstep.
Old 05-04-2017, 12:18 AM
  #39
myw
myw's Avatar
lol no joke, i actually was going to plan some work related trip in the 911 to columbus as i have colleagues there (and to get some side splitters added!!!) lol
platinum you're only 5 hours away!
Old 05-04-2017, 07:36 AM
  #40
platinum997
Road Trip !
Quick Reply: DIY Custom Side Splitters >>
