Lowering springs, LH side 3/8 lower than right side
Vogtland springs installed 1 year ago not sure if it was like this since installed?
Both front and rear LH is lower than right measuring at fenders.
Should I buy new springs or add compensation plates to the left side?
I assume you're on stock dampeners and not coil overs as that would make the adjustments straight forward and simple. First, I would make sure the springs are properly installed and seated into the strut top caps. If one tech was working on one side of the car and a different tech on the other side, maybe one side was done incorrectly. Also, I'd have your alignment checked. Camber settings could create a ride height difference - I wouldn't expect it to be 3/8" but who knows.
Should I expect the shop that installed the springs to fix it for no charge????
