Who has a 997.2 tune, fabspeed intake, IPD plenum, headers,etc
They also can address gas pedal sensitivity if you would like to change.
Their tune was worth it in my case. Tighten the mods and feels the engine runs much smoother and seems to rev better from standstill with a small low end torque improvement.
They sent my tune with a higher rev at idle at about 50 to 100 above stock. They say sometimes needed to address rough starts from a standstill with an xpipe, PSE, and PDK. I asked they remove and e-mailed me a new file with stock idle to test and very accommodating.
My set up had no issues at stock idle and stayed with it at stock. I'm not the kind of driver that likes my car at a higher idle at a standstill.
Bottom line, made a difference and would not go without a quality group's engine tune to pull these mods together. Other mods I found easy and made a material improvement was PASM stock swap out with TPC's DSC sport controller
Sorry to throw cold water on the ECU tunes but I've done both - sent my ECU out to a reputable vendor and had my car dynoed tuned. On the ECU tune it was not a good experience and one of their "tricks" was to change the throttle response to make the car feel like it had more power. To get an effective tune in my opinion you need an expert running your engine and looking at outputs - especially if you have any mods. A before and after dyno will be your proof.
My opinion. Unless your buying a power package with a tune all from the same company your not going to see the results your expecting. Adding an exhaust from manufacturer A, Intake from B, plentium from C and a off the shelf tune from D isn't going to be the same. The parts are not tested together and tuned appropriately.
You might get lucky and have some gain but surely not as much as a planned and tested system.
If your going a la carte, get a custom tune.
I also agree with software tuning a stock car. Not much gained. It's when you add hardware mods and work a tune to take advantage of changes. It did for me and evomsit had previously created a tune for my specific mods
I have 997.2 S4
with Fabspeed
X pipe
Sport Headers
Fabspeed Tune (they source it out and use a “my genuis”
Cold Air Induction
car kicks ***. Sounds like what a 911 should sound like- lower bass notes and a banshee wail at redline. Loads of torque, horsepower. About 430 Hp I’m guessing, due to fact I easily pulled away from a 2017 s on the highway and just took at M4 last night. I have an s with sport chrono etc.
QUOTE=ChicagoSpeed996;14098388]i picked up a 997.2 with a VR tune and I'm not happy with it. I get some ping at part throttle, I imagine they just bumped the timing and it's too much and the engine pulls it back. Current mods:
fabspeed intake
GT3 throttle body
IPD plenum
M&M headers and cats
i am looking for feedback on tuners, especially people with the same or similar combos. I don't need much more power, just want safe drivability. I am thinking of going with FVD as they work with M&M exhaust. The exhaust has the cats relocated similar to a 997.1, which may cause some tuning difficulty?
Thabks for the help![/QUOTE]
with Fabspeed
X pipe
Sport Headers
Cold Air Induction
fabspeed intake
GT3 throttle body
IPD plenum
Full fabspeed system on turbo.. put the Cobb on and was completely different car, had purchased the Fabspeed tune and then added it... excellent, but I think Cobb was 95% there ... especially for the street.
06 C2S with Fabspeed intake and complete exhaust
Came with the car when I purchased it two years ago, excellent customer support from Fabspeed, great sound, and no problems. Never had the opportunity to drive it stock. I do love the fat midrange torque compared to my previous 964.
Larry in Georgia
06 C2S
03 Audi S8
67 Chevy C 10
09 A4 Avant Wifey
Larry in Georgia
06 C2S
03 Audi S8
67 Chevy C 10
09 A4 Avant Wifey
fabspeed intake
GT3 throttle body
IPD plenum
fabspeed intake
GT3 throttle body
IPD plenum
200 cell cats k&n intake these IMO would be the biggest easiest/difference, also had Lw flywheel and pulley, headers and Lsd. Haven't had tuning yet, but car is easy to drive with good pull from 20mph in 3rd and from 50-100mph is fab
60-100mph is around 4.5sec.
no flatspots to speak of but not had it tuned yet.
Russ
Hi there! I'm doing preliminary research on IPD plenum and found your post very relevant. I've done the sharkworks x-pipe and now at the decision point of going with EVOMS ECU flash or IPD plenum. Talked to Sharkworks and they advise software tune ahead of plenum swap to get the most value. What are your thoughts on the correct order of these upgrades? Thanks in advance!
Hi,
I've since put on muffler bypass so car is very loud and 50lbs lighter, however, to answer your question, I recently had a remap, I think these are just about the same whichever country you are in and whoever does them, for me it's UK, it seems to be more of timing and throttle response, they all seem to quote 15 to 25hp, I think 15 is realistic, when it was remapped I could feel a lot of throttle response which made it feel a little more powerful and there was a slight increase in power, it also made the car louder and mine is already incredibly loud, too loud to use in town. It just felt a bit harsh even for me, I felt the throttle response would make some overtaking a little tricky, it's a bit like all or nothing, it a felt like I was asking too much from the car, so I had the original map put back on. I'd go for ipd plenum,
It just looks like a piece of art and will work with the increase flow from your exhaust the ecu will adjust fueling accordingly, put lsd on when you get a chance.
Basic Sponsor
Phil here.
In any NA vehicle I would suggest completing all mechanical parts before tuning.
You can only pull so much hp out of these cars so if you can tune for all parts that you are putting on you can extract the most HP.
If you do it the other way around you won't see the benefits of some of the parts.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Phil here.
I would agree with you, but in most cases isn't the map just off the shelf, so to speak, for instance the one they put on my car was just a map for 997s regardless of what mods had previously been done.
So the map just adds a little bit more fuel, adjusted timing and throttle response, so unless it's tailored to a specific car+mods it shouldn't make a difference to the order things are added
Obviously if you are having a tailored tune then it has to be done last.
Russ
Thanks Phil. Makes sense to get done with hardware upgrades and then utilize software to bring it all together. Do you have experience with EVOMS? If you do, any thoughts you could share?
Basic Sponsor
Hi Phil,
Russ
Russ
That is true if you are ussine of the shelf map.
I have not had much experience with ots maps on NA engines. I use them a ton on Turbo engines because it is a great stepping stone but would not suggest using them on an NA engine.
Basic Sponsor
