90k Service
90k Service
Going in for 90k service on Tuesday... any suggestions? Everything working well (knocking on wood right now!). I've done water pump, spark plugs, belts and hot-start cable in last 25k miles... I'm thinking oil change, rear tires, cabin filters, check brakes, check AC, plus I'm installing a P short shifter.
Any other preventative stuff that you guys can recommend? Thanks
For 997.2 C4S there is not a major service at 90K. Most of that came at 80K ... plugs, air filters, cabin filter, oil and filter, wiper blades, inspections.
Of course there are time out intervals as well and these could put you out of sync with some of this.
A bit more detail on your car might make it easier for people to make suggestions.
