My little week-end scare
It started with some small vibrations and I thought first that the shock absorber was having a problem but then it felt like there was no damping effect at all, and when I took the last curve left before arriving home (100 feet away), it felt the whole front right suspension collapsed... in the garage I look below and there was some hydraulic fluid... The wheel in itself looked OK, so I took it off and ...voila...: the whole lower arm bolt/nut was missing! how on earth this thing can unscrew? As I walked back toward the last curve before my house, here it was: I found the bolt on the road but not the nut; I replaced the nut (found one similar at ACE and a lock washer, but I already ordered the genuine one(s)) and the fluid is from the front differential (it's a C4S)... Other than that, no major damage, I think I have to re-do an alignment ? also I saw on ECS that they have these competition bushings that can adjust the camber, maybe it is a good opportunity to change these one as well, after all this grandma is 100Kmiles... although an hour before that, she was still doing 120mph... I just imagine what would happen if the wheel flies off at this speed.... Anyway, I guess I am going to re-check all these suspension elements on all the car, otherwise I'll get a bit nervous at speed...
front differential oil.. not much lost, but how can I check if the level is still ok?
OMG!
Here it is, found it back on the road!
OMG!
I discovered mine was loose because I heard noise when going over certain bumps/depressions.
Purchased new nut and bolt and tightened to I think 90# but a Tech at an Indie said I should/can tighten it more because the bolt takes a lot of torque when cornering. So I think I went up to 120#.
If the ear mounts are ovaled from the loose bolt wearing out the hole you want to make sure it's tight. So far mine has stayed tight, don't think I had ovals. I don't DE the car. The ears are part of the under carriage, and if you have to replace the under carriage I think the job is 2-3k. An alignment is a good idea after replacement.
This is not as uncommon as you might think. This happened to me too but I caught it before it backed completely out. I posted about this in the race/DE section. Here are the links with some comments:
https://rennlist.com/forums/997-foru...acked-out.html
https://rennlist.com/forums/racing-a...on-common.html
diff leak from damaged front suspension
I think this is because when the right wheel turned and the lower suspension link snapped off due to the missing bolt, the front right axle exerted a pull and maybe slightly unlodged the bearing or unseated the right seal/boot and hydraulic oil leaked...
How do you check front diff. oil level to see it is ok?
Ok but remember I did this on my own, I *think* it was 120 IIRC, it was a while ago. The spec is 89 so if the threads give, don't hold me in contempt! Also you don't want to bend/damage the mounting ears. Maybe do 100-110 and see if that holds for you?
