Anyone tried Ohlins Road & Track?
#32
Originally Posted by nowakm99
Thanks for the feedback. I just pulled the trigger on these yesterday and should have them on the car in 2 weeks. They were actually almost $1,000 less expensive than PSS9s here in Canada, so a no brainer.
#33
Dumb question for guys who DIYed this install: How does the rear adjustment **** come off so you can put the top hats on? Just unscrew the nut that the **** is on? Pull up on the **** and then unscrew the nut?
Slightly less dumb questions: Can/how did you torque the lock rings to spec with the spanner wrench? Or just go by feel and tighten them firmly or tighten them as much as you can? How about torquing the top nuts? Can somebody point me to appropriate sockets/tools?
Got the old struts off yesterday. Not too bad of a job and knowing how to DIY will come in handy when it's time to rebuild them. Really excited to get the Ohlins on!
#34
I run Öhlins DFV R&T on my modified 2006 MINI Cooper S: the adjustability is very helpful for trackday, summer and winter set ups. There's no comparison at all to the standard "Sports Suspension Plus" which was basically awful: stiff and uncomfortable springs with crappy dampers. The Öhlins are also very light which is beneficial for unsprung weight. The springs are a bit softer than the Bilstein B14s that I ran on the MINI earlier, which were truly excellent on the track, but definitely too firm for the day to day.
I'd definitely run Öhlins on a 997 if it was fitted with passive suspension, but I have PASM and the TPC Racing DSC controller, which works very well.
#35
I recently switched from PASM/Eibach spring/TPC box to the Öhlins R&T set up. It’s truely impressive what these passive “old” shocks can do.
rides better than before and still handles well, only downside is have to turn 4 ***** for the track vs 1 button in the console.
#36
I'm so torn on this issue. It's time to replace mine and I'm torn between Damptronics with a DSC box and the Ohlins. I do about 5 DE's a year and enjoy many Canyon runs. The Ohlins sound awesome but the service interval seems like a pain. Based on my driving I'd have to pull them off about every 3 years and have them serviced. But, when I factor in the damptoinics and the DSC i'm up in the $5 range which exceeds the Ohlins by a significant amount.
#37
I got rid of my pasm for the ohlins. Love it, it’s much better with lots of feedback and much improved handling. Downside is the ride quality, it’s not great and for someone not used to running coil overs in their past cars they may not like it. Service interval is another thing to consider, though jrz I believe has an even shorter service interval
#38
I would have gotten the bilstein damptronics, however they are on intergalactic back order.
from a PASM replacement perspective it was stock or trackactive for $6500.
The future is PASM and tcp box, however it’s still not at the Öhlins price point, and the ohlins are still really darn good.
#39
#40
Thanks for that info. I have gone upto 18 clicks from full stiff front and rear. It is just about ok for daily driving. Will give 23-24 a try and see if it makes significant difference.
#41
Maybe someone can help me with the installment of the front shocks, as I am not sure on one detail: I plan to replace the whole strut, as the front strut top mount is fairly cheap. There are only small pieces to replace (dust cover, nut,two washers)
But: the original strut has a real ball bearing and another plate/washer below this steel/rubber top mount, but in the original instruction only this top mount is visible and described. What about this ball bearing? It would be helpful if anybody could at least post a close picture of the strut, displaying that area. Thank you
#42
I'm in the middle of changing to the Ohlins R&Ts on my 997.1. I replaced the top strut mount/hat (99734301801), bearing/housing (99634351505), 6.5 mm compensating plate/shim (99634351101). [Take pictures as you disassemble the strut to be able to get the assembly order right.]
#43
I've been thinking about refreshing my Turbo's suspension in the next year or so. Goal is some tasteful lowering and upgraded sporty ride quality.
Until this thread, I assumed that the best setup short of $7k Tractives would be Damptronics + a DSC box. Now I'm thinking, for someone like me who drives only on the street and almost never flips between normal/sport modes, maybe the passive R&Ts set to my taste would actually provide a better ride (firm and compliant but not "crashy," as mentioned earlier)?
Does a good old fashioned passive setup like the R&T beat the Bilstein/TPC duo if you don't really need on-the-fly adjustments?
#44
The nut 10 and the washers 6 are clear. So you reuse 11, the bearing. The compnesating plate is 5 and 4 is a metallic washer. Do you use this as well? What about 2, a small washer. We do not need 9, the absorber?
Thank you, maybe you can take pictures.
#45
The instruction booklet that comes with the ohlins clearly shows what oem parts to use on the coilovers. I don’t have it with me right now but will try to get a pic.
