Zunsport Mesh Grille Inserts-Fitment
I am only doing the center grille from Zunsport because I have not found a way to attach a center grille without taking off the bumper. I did the two side grilles with the "under $20 " Diy that I found on youtube. I believe that the guy who made the video is a rennlist member. anyway, imo, I think the diy is the better way to go for the side grilles as the mesh looks better behind the grilles and is so much cheaper to do. I think I spent about $8 and here is a pic of my result.
Thanks for getting back to me. That information definitely helps. that looks like you ordered the grille "set". I only want the center grille (zpr32505b). this is what I ordered.. it looks like the center grille in the set you ordered is zpr32505b so I must have the right one. thanks again. was there any drilling involved in the center or just clips?
Bringing this thread back to life, sorry. So as a DIY guy, i sourced some mesh and installed them from behind while the bumper was off. Looked great until i realized that i created a clearance issue with the rubber ductwork for the radiators. The ductwork fits into the trim pieces themselves. So I'm curious from those that mounted them from behind, how did you do this? I'll assume they were trim to fit exactly in a way that the ductwork still found its home.
Thanks!
Thanks!
