Anyone have issues with the frunk refusing to open once in a while?
It's happened 3 or 4 times - frunk will not open for an hour or 2 and then once you park it in a garage/cool place it lets you in. Any solutions?
Is the problem with only the switch next to the driver's seat, only the remote, or both?
My switch needs to be pulled up and pushed back to work. My remote has always been fine.
Heat works against solenoids, especially if the battery is marginal or there are connections issues (there is no such thing as a good connection).
Great, so far it seems mine is special. I tell you what if it locks me out from grabbing a beer on my next roadtrip pit stop i'm dumping the car.
Good, so you can rule out the switches. It's either the electrical locking mechanism or a misalignment of the hood/latch mechanism that is made worse while sitting in the hot Florida sun. If your car is accident free I vote the locking mechanism is going.
By the way, there is an emergency manual release cable in the LF wheel well underneath the plastic liner. It's a pain to get to often requiring the wheel and liner to be removed. Just be aware in case your frunk opening completely dies.
And, of course, keep your wheel lock key in the glove box.
I also think I saw somewhere the the release is accessible through the driver's side front parking/turn/fog light assembly hole, as that would be much easier than having to remove the wheel & liner. Maybe check that out. To get the front light out, you just need an old hotel card key, at least that's what I use as it's a bit stiffer than the card Porsche gives us for the purpose, and the LED front light assemblies fit tighter than the OEM ones so the card will get a bit beat-up over time. Better to not use one of your credit cards because of this.
